5.4 spitting out plugs..... - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 05-24-2003, 02:42 PM   #1 (permalink)
My Photos: (31)
Send a message via AIM to DshiftFF
My boss has me go out to look at his van on his lot, 5.4 V8 98 E350. says he was driving it, made a loud pop and lost power but still ran. I was figuring something exhaust related, but upon inspection, found the individual coil all self destructed, snapping the mounting flange off, boot that goes into plug hole shredded and no sign of spark plug. It may be down in the hole still, but its of course the #7 which is a bastard to get at. also pulled codes and got PO300 PO307 PO357 and PO402 which are cylynder misfire related. anyone ever see this with a V8? What was your recourse for fixing this big bucks or what? any help appreciated. thanks....
1995 2500 CTD
2001 2500 CTD
2006 2500 CTD
I see a pattern emerging here
http://www.newenglandturbodieselpowe...rums/index.php
DshiftFF is offline
Old 05-25-2003, 01:43 AM   #2 (permalink)
Re: 5.4 spitting out plugs.....
It's more common than you think. This might fix it. http://www.timesert.com/bigsert.html If not then you'll have to pull the head.... $$$
2005 V10, AT, Fx4 Dark Stone Metalic, Crewcab F350, 4.10LS, shortbed, towcomand, Extang tonno **SOLD**
2007 Dodge 3500 Quadcab, 4x2, 6.7L Cummins, a/t, longbed, 4x2
Silence is golden. Duct tape is silver.
V10 man is offline
Old 05-25-2003, 03:39 AM   #3 (permalink)
I may be missing something but here goes. I have not worked on that engine or even seen one, but have heard of this happening.
Are the threads still in the plug hole and are they OK? It sounds to me like that plug, which has probably been changed at least once by now, was not properly seated and worked its way loose. It blew out of there explosively and somehow hit the coil you speak of either directly of after having bounced off something else. I would guess the plug is out on the road somewhere. The plug wire whipping out when the plug boot was shredded, may have damaged the coil as well.
ChrisB is offline
Old 05-25-2003, 10:55 AM   #4 (permalink)
My Photos: (31)
hope not for his sake$$$
unfortunetly the hole for the plug is directly under the dash (E250) so we could not see down there. The plug was gone so couldnt check the threads on that either..hes gonna have it go in for service so we will see whats up by tues....
1995 2500 CTD
2001 2500 CTD
2006 2500 CTD
DshiftFF is offline
Old 05-27-2003, 10:14 AM   #5 (permalink)
$10 says it is the #3 cylinder. Very common!
99 f250 V10 4x4 c/c lb
dadomin8r is offline
Old 05-27-2003, 10:44 PM   #6 (permalink)
Um, he said it was #7 in an earlier post. Feel free to send the $10 my way.... [img]/ubbthreads/images/graemlins/grin.gif[/img]
<font color="blue">There are two rules to success in life: 1. Don't tell people everything you know.....
2000 F-350 XLT CC SRW 4x4 LWB V10 Auto 4.30LS. 10.5" lift, 39.5" Swamper TSL's and Dynatrac combo kit.
click here for pics</font color>
keithf is offline
Old 05-28-2003, 08:38 PM   #7 (permalink)
My Photos: (31)
turns out that it just vibrated out, local mech. replaced the plug and it took to the threads also needed new coil. boss sure was happy about that.... ford stealer said $3800 if they needed to pull the motor [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img]
1995 2500 CTD
2001 2500 CTD
2006 2500 CTD
DshiftFF is offline
Old 05-28-2003, 09:03 PM   #8 (permalink)
Run out and buy lottery tickets right now! You're lucky. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
V10 man is offline
