Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Gas Engines
Gas Engines Discussion of the gas engines available in the 1999-2007 Super Duty trucks
Old 12-15-2002, 07:15 AM   #1 (permalink)
5.4L gas engine
I have developed a dead miss in the engine that exists at all speeds. I'm sure one cylinder is dead. How can I determine which one it is with out any test equipment other than a multimeter. It has the coil pac ignition so there are no9 spark plug wires to remove or check with test light.
Paul
Paul338 is offline
Old 12-16-2002, 09:41 PM   #2 (permalink)
Re: 5.4L gas engine
Why can't you remove the wire going to the coil pack until you find the one that doesn't alter the miss?
Wonder why the check engine light isn't coming on for a miss? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Y2K Excursion
monsta is offline
Old 12-18-2002, 03:56 PM   #3 (permalink)
Re: 5.4L gas engine
strange but true, if a coil pack is not working on a certin plug
most of the time if you find the bad, or dead hole, and swap it with
another from a different location, it will work. as to the best way to
find the bad location, try the old unplug trick, when it runs the same with the coil pack unpluged, you found the problem. good luck!
78' supercab 4x2 with 71' t-bird 429 and c-6
98' ford expedition 5.4 for family
HARDCOREFORD is offline
Old 12-31-2002, 09:40 PM   #4 (permalink)
Re: 5.4L gas engine
i was told you dont want to unplug wile running or you can burn them up that way.
2002 F250 superduty 4x4 psd auto supercab xlt.weight7020.vdh4.2004 mach 1 compition orange.
guss is offline
Old 01-01-2003, 01:19 AM   #5 (permalink)
Re: 5.4L gas engine
Yes, you don't want to unplug high-output outputs from the computer
while it's running [img]/ubbthreads/images/graemlins/smile.gif[/img]
'01 F250SD V10 auto 4x4 SC SB
'74 F250HD FE390 4-speed 4x4 LB - heavily modified 390 (deceased)
akrewat is offline
Old 01-06-2003, 05:25 PM   #6 (permalink)
Re: 5.4L gas engine
Why don't you get the truck warm or hot .shut down and pull the coil pack and do a ohm /resistance chk ,look for one that that is different than the others. at the same time pull the plug ,look for different color!
[img]/ubbthreads/images/graemlins/shrug.gif[/img] Rich
4Tfords is offline
Old 01-12-2003, 02:05 PM   #7 (permalink)
Re: 5.4L gas engine
Warm the engine then shut it down. Feel each spark plug or around the exhaust port. You should be able to tell which one is not firing by the temp difference. Be carefull, you do not want to leave your hand there to long.
P.S. I carry a 12 v test light with that is capable of checking this. It is a heavy duty one from Snap-on that has a point on the probe similar to an ice pick. Just connect the ground and pierce the spark plug boot with the tip, enough to ground out the cylinder. Listen for the engine miss to either get worse or not change. When you get to the one that has no chage you've found it. After your done put a small dab of RTV over the hole you created.
2002, F-350, XLT, PSD, ESOF, Auto, 3.73, Crewcab, Shadow Grey, Long Bed, Camper Package, Lund X-Terminator, Ford Type 2 Tube Steps, Ford Molded Mud Flaps, Sidewinder Remote Start, Sonnax Valve/Tricummulator Springs, CR Lawrence Power Rear Window, Bilstien Shocks, REVO's, Reflex bed liner
2004 Keystone Everest 291L Fifth Wheel
TMace is offline
