I heard a rumor that Ford is going to make 5w-20w oil retroactive to 2000 Superduties V8 and V10, like the new 2001's. Has anyone else heard this? Is there any difference in the motors anyway [img]images/icons/crazy.gif[/img]
Y2k F350, white with harvest gold trim,V10,4x4,Lariat,SC,Auto,Tow pkg,camper pkg,ESOF, so-called limited slip, off road,3.73,Rancho 9000 w/ in cab control, Ride Rite Air Bags,Long bed,Rickson 19.5" wheels, Michelin XDE-MS,Lance Camper, BugDeflector2, Stull Grill, KN., Flowmaster 50
NoMo,
I am going to run the 5w-30w too until it is an official change by Ford, its just that my oil change company tells me that you will get better fuel mileage (less friction) and your oil seals will last longer with the lower weight oil. But like you, I don't want to give them any warranty excuses by using the "wrong" oil until THEY make it official [img]images/icons/wink.gif[/img]
Y2K excursion XLT 2wd, ordered july '99, built august '99, delivered september 9 '99, 4R100 fried & replaced at 900 miles still running like a champ
Ford TSB # 01-04-07 addresses making 'retro' the recommendation for 5w-20 oil in Triton engines for all years, V8 and V10, among other engine sizes. The reason seems to be for better fuel economy (a hot topic in this forum!)
I'm using Mobil 1 and I haven't seen 5w-20 grade yet. I've read opinions that Mobil 1 will find a place to leak and its use will cause the engine to use oil, but I've had good luck so far through 9k miles and three oil changes.
2000 Ford Excursion XLT 2WD, Chestnut/Parchment, V10, 3.73ls, autolamps/DRL's, Rear air deflector, Banks Powerpack with Transcommand, Edelbrock I.A.S's, 1 steel rear lift blocks, Tekonsha Sentinal. Towing a '00 Holiday Rambler 31 SKS, 10K gvwr
I understand from talking to Amsoil tech services that they are coming out with a API licensed, 5w-20 full synthetic in the next month or two. I would expect the price to be in the range of $5.00/qt, plus shipping.
Outpost22, I found it on the Ford Insiders Web site. I accessed this site with the disc I received in the mail after my Excursion purchase. It has the service manual and wiring diagrams along with service bulletins and recalls for the vehicle, on-line.
I was going to post a link, but when the web page with the bulletin comes up, it doesn't show the address. I'm sure you can ask your dealer to see it.
I pared it down some, but here it the TSB: (Looks like we are supposed to start using the 5W-20)
Article No.
01-4-7 ENGINE - ENGINE OIL - RECOMMENDED APPLICATIONS FOR SAE 5W-20 AND SAE 5W-30 MOTOR OILS - GASOLINE AND FLEXIBLE FUEL VEHICLES ONLY
Publication Date: FEBRUARY 20, 2001
1999-2001 F-53 MOTORHOME, SUPER DUTY F SERIES
2000-2001 EXCURSION
NOTE: PLEASE REFER TO THE VEHICLE APPLICATION LIST LATER IN THIS TSB FOR A COMPLETE LIST OF VEHICLES AFFECTED BY THIS TSB.
ISSUE:
Engine oil recommended for use in 2001 vehicles is SAE 5W-20 motor oil. This oil has an improved formulation to improve fuel economy. This oil can also be used to service some previous model year vehicles.
ACTION:
Use SAE 5W-20 engine oil at recommended oil change intervals for 2001 vehicles, with the exception of the following vehicles listed in the "Exception 2001 Vehicles" chart.
All 2001 vehicles other than those listed in the "Exception 2001 Vehicles" chart are being filled with SAE 5W-20 motor oil at the factory and should also be serviced with SAE 5W-20 oil.
Vehicle Application Listing Approved For SAE 5W-20 Motor Oil
1997-2001 4.2L (SPI) F-150 (under 8500 GVW only), Econoline
1997-2001 4.6L 2V Triton F-150/250 (under 8500 GVW only), Econoline, Expedition
1997-2001 5.4L 2V F-150/250 (under 8500 GVW only), Expedition, E-150/250/350, E-350 Chassis/RV/Cutaway
1997-2001 6.8L E-250/350, E-350 Chassis/RV/Cutaway
1999-2001 6.8L Super Duty F-Series 250 HD/350/450/550 Motorhome
2000-2001 5.4L/6.8L Excursion
NOTE: THE "EXCEPTION 2001 VEHICLES" SHOULD BE SERVICED WITH SAE 5W-30 MOTOR OIL.
Engine Vehicle
2.5L Ranger
3.3L Villager
3.9L Lincoln LS
4.0L Ranger, Explorer/Mountaineer, Explorer Sport, and Explorer Sport Trac
5.0L Explorer/Mountaineer
NOTE: IF VEHICLE IS NOT LISTED IN THIS APPLICATION, SAE 5W-30 OIL IS RECOMMENDED. REFER TO TSB 99-8-16.
PART NUMBER PART NAME
XO-5W20-QSP SAE 5W-20 Motor Oil - Quart (USA)
CXO-5W20-LSP12 SAE 5W-20 Motor Oil - Litre (Canada)
XO-5W20-5QSP SAE 5W-20 Motor Oil - 5 Quart Jug (USA)
XO-5W20-DSP SAE 5W-20 Motor Oil - 55 Gallon Drum (USA)
CXO-5W20-DBSP SAE 5W-20 Motor Oil - 205 Litre Drum (Canada)
OTHER APPLICABLE ARTICLES:
99-8-16
WARRANTY STATUS:
INFORMATION ONLY
OASIS CODES:
401000, 490000, 497000, 499000
'00 F250 CC SWB 4x2 XLT V-10 Auto 3.73LS Silver/Graphite
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Sport: WARRANTY STATUS:
INFORMATION ONLY <HR></BLOCKQUOTE>
Thanks for the information guys! Looks like 5W20 really isn't required, just "recommended" for the pre-2001 models. Until supplies/brands/choices get better, I think I'll stick to the Mobil 1 5W30.
I'll keep running 5w-30 full synthetic. Anyone that has ever drained the MotorCraft 5w-20 knows that stuff reeks. Call me finicky, but oil shouldn't smell like a feed-lot, after only 1000 miles.
Just my .02
2001 F251 SRW Lariat CC 156 4x4, V10, 4R100 Auto (#3!), 3.73 LS, ESOF, BU sensors
OffRoad, Camper Pkg. Born, KTP: 08-01-00, Delivered: 8-29-00
SCMT, Volant intake, Gibson stainless cat-back exhaust, PML ALu trans pan and diff cover, Snuglid, 285x75R Geolandar AT II+, Edelbrock IAS shocks.
Hey guys!
I called my dealers service department (Mock Ford in Grants Pass, Oregon) today and they said go ahead and run the 5w-20w in the 2000 V10 as that is what they understand to be right and that's what THEY are putting in the 2000's (I didn't ask about 1999 but assume that also is true as it's in the TSB)
So, next change I'll give it a try.
I'm sure there is nothing wrong with running the 5W20. Just waiting for some more options other than Motorcraft dino lube. With Ford trucks being so popular, I doubt it takes long for the oil companies to start cranking out the new weights.
I recently read an SAE paper published by Honda on the topic of 0w-20/5w-20 motor oils. As far as I could tell, the only benefit was a fuel savings of 1.5%, compared to running a 5w-30. I would still use a 0w-30 synthetic over a 5w-20 petroleum oil in this application. Ford can claim a corporate fuel savings by going this route.
BTW, there was no difference in wear protection between the 0w-20 and 5w-30 petroleum oils in this study.
