98 wont shift out of park - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 09-01-2009, 07:28 PM   #1 (permalink)
abjacq's Avatar
i have a 98 f-150 that will not shift out of park. it was working fine the other day, all i did was park it, and i couldnt put it back into gear. tried rocking the truck back and fourth, but nothing. replaced the brake switch and that changed nothing. when the brakes are applied, the brake lights do not turn on and the abs light starts flashing. checked the fuses and couldnt find anything blown. anyone have any ideas? im stumped with this one..
2000 f350 crew cab short bed 2wd. Glowshift guages, magnaflow stainless exhaust, DP Tuner. paid 3,000 for the 245k miles it had. up to 260000......SOLD
1999 f250 ex cab short bed 4x4 K&N air filter DP Tuner (stock, 80 economy, 120 race, 140 aggressive, lope idle) 4in exhaust airbags autometer gauges built tranny 305k miles! -SOLD
1999 f250 ex cab short bed 4x4 350springs 170k built trans DP Tuner (stock, 60 tow, 80 econo, 140 aggressive) 4in banks exhuast glow shift guages 8ft boss plow
2003 f250 crew cab lariat 4x4 240k miles, 9'2'' BOSS V plow
2002 f250 crew cab lariat 4x4 355k miles, 8'2'' BOSS V plow
abjacq is offline
Old 09-01-2009, 08:00 PM   #2 (permalink)
carringb's Avatar
Brake circuit fuse. swap it even if it looks okay and see if it helps.
To get it out of park, turn the key forward one click from lock, but keep in OFF. You can now shift from park. Place it in neutral to start.
2000 E350 DRW XLT extended wagon (yes! it's a dually!)
17" Ultra Goliath rims
Banks Powerpack, Diablo Predator
Buckstop front bumper, Reunel rear w/ 20,000# reciever
250,000+
carringb is offline
Old 09-01-2009, 10:41 PM   #3 (permalink)
abjacq's Avatar
well, it worked to move the truck. but still, as soon as the brake is it, the abs light flashes. not too sure what this means
abjacq is offline
