99 F350 SD 4x4 - MANUAL FRONT HUB REMOVAL... - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 11-09-2008, 01:03 PM   #1 (permalink)
99 Ford F350 4x4 with Manual front hubs. I am trying to get the front hubs off my truck to greese them (very hard to turn) and I can't seam to get them off. Wanted to see if there was a trick or somting.
The Chiltons manual I have says to remove the tire...front caliper & disk... then the clip retaining the hubs and then it shows thehub just poping out.
I did above and can't seam to get the hub off (don't see why though, do you really need to remove the wheel and all?). remove the retaining clip and pull on the hub and it won't budge...
Thanks for any help!
Chris
cmb1998 is offline
Old 11-09-2008, 06:02 PM   #2 (permalink)
If your talking about the 4x4 locking hub all you have to do is take off the center cap and then take the snap ring out and the hub will slide right out.
1996 F-350 7.3PSD,CC,LB,DRW,2WD about to roll 400,000 miles (Dad's old truck that we now just use to haul nasty stuff and pull up stumps)
2004 F-350 6.0PSD,torqshift,Lariat,FX4,CC,LB,DRW(Dad's tuck)
1999 F-250 5.4 gasser, lariat, 4x4 offroad, ext cab.True duals with magnaflow X muffler, 2.5" leveling kit,K&N intake, poweraid throttlebody spacer, procomp es3000 shock absorbers, 33"nitto terragrapplers, line-x bedliner, Front and rear ranchhand bumpers. 10mpg and the slowest truck in town but its still a badass
matthassey is offline
Old 11-09-2008, 10:59 PM   #3 (permalink)
My Photos: (14)
Send a message via AIM to edub32
mine were a pita to pull out so i just took a rubber mallet to them to loosen them up.
2001 F350 7.3 SCLB 4x4 Off-Road SRW
- DP Tuner, Tymar intake, 35" BFG Mudders on 16x10 Mickey T's, Superlift 6" lift, DiPricol 3 gauge Pillar, 4" SS DP to 5" sidepipe to 6" Chrome tip, WW, Panasonic Deck with 4xInfinity References, Overboost Elim., CCV
edub32 is offline
Old 11-10-2008, 10:37 AM   #4 (permalink)
Thats what I am talking about...but neither of mine want to come off. So long as I am not going to break anything I might give it a little more muscle.
Thanks for the help.
Chris
cmb1998 is offline
Old 11-10-2008, 01:25 PM   #5 (permalink)
I had one that didnt want to come out and me and my buddy grabbed the edges with channel locks and pulled them right out
