Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Gas Engines
Gas Engines Discussion of the gas engines available in the 1999-2007 Super Duty trucks
Old 07-08-2003, 01:58 PM   #1 (permalink)
HeavyAssault's Avatar
My Photos: (6)
ACCUFAB Throttle body
This is not for the weak hearted. I have been installing several goodies since I've been home. First was a MAS from Granatelli and a K&N FIPK. They were working pretty good together. I have some limited MPG results of 12.2-12.5 mixed city/hwy using the AC. Now the new TB. I first will say the product is top shelf and is really a work of art. VERY nice billet and very well built. The install was a snap and
on in less the an hour. The TPS will be the hardest part to get off the old and on the new. Care should be given not to strip the phillips head screw. The test drive was a "normal" drive to the gas station. Not using excessive throttle or habits. With a full tank I rolled home to see what it would do. I was already moving when I stomped the gas. Well it down shifted and the RPMs went to 4700+ before shifting to second. I came off the gas as I hit 70 and figured the shift was too late and I needed to do this from a stop. I u-turned and stopped. The road was clear and I put it to the floor. I must say the truck took off and once again didn't shift till 4700+RPMs. I had to slow down since I was running out of road. I will continue to test this and see what if any adjustments are needed.
I got what I paid for, and I love the new found power.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some "deleted" stuff.....
HeavyAssault is offline
Old 07-08-2003, 02:51 PM   #2 (permalink)
My Photos: (6)
Re: ACCUFAB Throttle body
Cool, so how much did all this new found power cost...? Where did you find your Throttle body?
ohski is offline
Old 07-08-2003, 03:48 PM   #3 (permalink)
I second what ohski said... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
My Truck - 2004 F350
DJ's Diesel Performance
CBSUPERDUTY is offline
Old 07-08-2003, 06:11 PM   #4 (permalink)
My Photos: (6)
I picked up the MAS for $185 and the K&N kit for $192 both off EBAY. The throttle body, made by ACCUFAB, is from Proficient Performance for $385. I chose three day shipping so the cost was higher.
Old 07-08-2003, 06:48 PM   #5 (permalink)
After install did you unhook battery???for 30 min.????
Let the brain take in all the new goodies.
How many miles on truck?? and what octane are you running?
twinbulls
1999.5 F-250 Lariat SD CC SRW LB Loaded V10 auto 4x2 K&N FIPK,Poweraid spacer,muffler deleted,custom seat covers,wood dash kit,tinted windows.BFGs 285s. A-Pillar gauges Tranny temp,oil pres and water temp.Hypertech PP 111 with themostat 160 deg.
ARE Custom Top W/ladder rack,Added a center seat/armrest,Clear corner lenses,TT mirrors, Rancho RS 9000X with incab remote, A work truck you can valet. NRA Life member.
My Truck
twinbulls is offline
Old 07-08-2003, 06:50 PM   #6 (permalink)
My Photos: (6)
Ok, I can't find that Accufab makes a Throttle body for any truck besides the Lightning. [img]/ubbthreads/images/graemlins/shrug.gif[/img] Good deal on the MAS by the way...!
ohski is offline
Old 07-08-2003, 08:00 PM   #7 (permalink)
My Photos: (6)
Yep...unhooked the battery and it ran for 10 mins at idle. I'm running 93 using the PPIII. I just kicked over 68k and it is running just like new.
I have researched the TB thing for a while now, the 96-98 COBRA 4v application is what I used. If you research any TB application for the V10 you will find they (Cobras' and V10s) share the same part number. I just like the idea of a single blade VS the two port 65mm set-up. The flow rate is nearly the same as is the cost for either set-up.
I just wanted to test the other so we could have options.
Old 07-09-2003, 08:24 AM   #8 (permalink)
My Photos: (6)
Cool deal man... Thanks for the info.
ohski is offline
