Wife has a 98 windstar with dual air ,rear air stoped being cold now only blows out at bottom hot, very hot! any ideas??Switch is on high ac.all fuctions work but heat comes out no ac.Any help before I take it to the shop and pay their mortgage.
1999.5 F-250 Lariat SD CC SRW LB Loaded V10 auto 4x2 K&N FIPK,Poweraid spacer,muffler deleted,custom seat covers,wood dash kit,tinted windows.BFGs 285s. A-Pillar gauges Tranny temp,oil pres and water temp.Hypertech PP 111 with themostat 160 deg.
ARE Custom Top W/ladder rack,Added a center seat/armrest,Clear corner lenses,TT mirrors, Rancho RS 9000X with incab remote, A work truck you can valet. NRA Life member. My Truck
The rear heater controler is not getting vacuum. The dash mounted controller is bad. It is an easy fix if you have any basic mechanical skills.
Pull the access panel off at the rear a/c unit-left side right behind driver's seat-Locate the vacuum hose going to the heater controller actuator,remove the hose. Start the engine and cycle the rear selector knob and check for vacuum at the hose. If there is no vacuum, then the controller is bad. If there is vacuum, the vacuum actuator is bad. Good luck.
Thanks I will try it this weekend.Iam very handy when it comes to fixing things,Or adding mods to my TRUCK, [img]images/icons/wink.gif[/img] Just point me in the right direction....
Thanks Ford Boy, Did what you said and NO
vacuum so i unhooked the vacuum actuator arm and the ac is now working, I know this is just a temp fix,but here in south FL one needs as much AC as possible,never used the heat. By controller you mean front ac/heat switch??I looked under dash followed white vac hose it went right to the ac/heat switch?I think?
Just want to say THANKS again!!!Iam sure a shop would have spent some time finding it,and time is my money.If you are ever in Ft.Lauderdale I'll buy you a beer... [img]images/icons/wink.gif[/img] This site is GREAT for all kinds of Info!!!!!
We keep these forums open for discussion regarding the Ford SuperDuty trucks. This one concerns those trucks that have gas engines. The only spot we have on the site for things like this is the Other Forum.
