Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Gas Engines
Gas Engines Discussion of the gas engines available in the 1999-2007 Super Duty trucks
Old 11-17-2007, 08:15 PM   #1 (permalink)
Axle ratio
Does anyone know the logic behind Ford only offering the 4x4 V-10 with the 4.10 axle? I have a 6.0 that I am about to trade. I had a V-10 several yrs ago that I was pleased with and it had a 3. something ratio. Could it be the 18" tires?
2003 F250 4x4 6.0 PSD Auto trans
JDeereGn is offline
Old 11-17-2007, 10:56 PM   #2 (permalink)
Re: Axle ratio
You can also get it with a 4.30, not just the 4.10. (ordered mine with the 4.30LS and 4X4)
I suspect you're correct in that the taller tires are behind the option.
08' F350 Reg Cab 4WD V10/6SPD/4.30LS
Ugly-Jeep-Truck is offline
Old 11-18-2007, 09:56 PM   #3 (permalink)
Homegrown's Avatar
Re: Axle ratio
You're assuming correctly, Ford dropped the 3.73 rear end when they changed the wheel size from 16", and the Torque-shift trans was introduced. As I told the Chebbie driver after I unstuck his truck with my 40 HP tractor "It's all in the gearing...". [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
FOKISD Charter Member from Hillsboro, OHIO
'01 F-350, XL, SC, LWB, V-10, 4R100, 3.73 LS, High Back Buckets, TT Mirrors, Roof Lights, Camper Package - Check my Photo Gallery for modifications. Michelin LTX M/S on Mickey Thompson Classic II's, A.R.E. DCU cap, Reese Titan V and Draw-Tite front reciever, Audiovox cruise control, Wolf center console, Truck-Lite rear ID bar, Hella FF75 driving lights.
Homegrown is offline
Old 11-18-2007, 10:00 PM   #4 (permalink)
Re: Axle ratio
Just so I understand. The 4.10 with the larger diameter wheels puts the same ratio to the ground as the old 3.73??
JDeereGn is offline
Old 11-18-2007, 10:11 PM   #5 (permalink)
Re: Axle ratio
In theory.
Old 11-19-2007, 02:48 PM   #6 (permalink)
Homegrown's Avatar
Re: Axle ratio
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ralph_McRae</div><div class="ubbcode-body">Just so I understand. The 4.10 with the larger diameter wheels puts the same ratio to the ground as the old 3.73?? </div></div>
To say yes to this would require knowing the exact outside diameter of the tires and gear ratios of each gearset in the transmission for both the old and new drivetrains. The short answer, as wickedsprint said, is "in theory". Here's a LINK to a website with some handy calculators to make the calculations a bit easier for you.
