To chip or not. - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 10-07-2000, 06:24 PM   #1 (permalink)
To chip or not.
I decided to keep my 99 V10. I have already installed a Banks Stinger system. Would like to install a "chip". Anyone have an idea what would work good with this system? Do you have to burn premium after adding the chip? I have heard both yes and no to this question. Anyone with first hand knowledge? The stinger system helped, but never have to much power. Any advice would be appreciated.
99 F250 SC long box, 2WD, V10, Auto, 4.30LS, White, Lariat, Trailer Tow, Camper pkg,
2001 F350, Lariat, CC, LB, PSD, Dually, 4X4, 6 speed, 4.10 LS, all manual, oxford white, graphite interior, captain chairs, trailer tow, camper pkg, trailer tow mirrors. ISSPRO pyro and boost ev gauges, 4 inch DynoMax cat back exhaust. Straight pipe at moment. Jordan 2020 Ultima, Pullrite 18500 super 5th hitch. Dee Zee fifth wheel boxes (front and rear).
2000 Excel 33ft, double slide, 5th wheel,
__________________________________
Member since May 2000 from Iowa
V10T is offline
Old 10-07-2000, 08:07 PM   #2 (permalink)
Re: To chip or not.
V10T,
I have a Banks PowerPack and a SuperChip on my 2000 V-10.
I love the Banks and the SuperChip. I went with the SuperChip mainly to "fix" the soft transmision shifts, but also liked the idea of the improved performance to along with the Banks Headers.
Unless you have a custom SuperChip programed you will have to run 92 or better octane fuel. If you have a chip programed to continue running the 87 octane fuel you will see very little performance/power improvements.
My SuperChip'ed/Bank'ed V-10 is getting 8% better MPG's (as long as I keep my foot out of it, so the fuel cost per mile is about equal. It will never pay for the Chiup and exhaist, but I din't expect it to.
You can check out some of my info at the following links: http://ic.net/~wawii/banks/ http://ic.net/~wawii/Dyno/ http://ic.net/~wawii/MPG/
2000 F-250 SD Crew Cab, Short Bed, Lariat, 4X2, V-10, Auto, 3.73LS
My Truck at the Dealer ----- My MPG File's ----- A Super Duper Crew Cab
Rear Wheel HP (Stock) ----- Rear Wheel TQ (Stock)
wawii is offline
