I couldn't tell through search if this question has been asked before.
The class A chassises use a 362hp 6.8L vs. the smaller van chassied class Cs with only 305hp. What is the difference? heads, cams, pcm tuning, etc? My E450 chassis with 340-350hp would be nice...
thanks!
94 F250 SC, 4x4, 5spd, 4.10ls, LuK, Toyo Country AT 285/16s, 190K, edge evo, shimmed FPR, Bilsteins, Add-a-leaf, 3"DP/4" exh, new ACs, ISSPRO, Term. 17* HPOP, pedestal mod, Tymar Intake and HPX, IDM and CCV mods
Re: difference between 305hp and 362hp V10s in RVs?
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mark Kovalsky</div><div class="ubbcode-body">For some reason (read:money) the E series never got the 3 valve engine. The Econoline program is about the stingiest program in the company.</div></div>
That is why it is called econo line...............
Remember when you could get a custom cab? That was a plain as it got. It was the bottom of the barrel.
1996 F-250 extended cab long box five speed. Home made Tymar, 203 Stat, 60 gal in bed fuel cell, 315/75's, no cat, no muffler, ebpv welded open 3" to 3" DP, Babies. 255K, still chugging, and still smoking when cold.
It has to do with the room under the Dog House of a Class C motorhome. The engine compartment is so encased that it is difficult to keep the compartment cool. If you check any of the Class C forums you will see a number of post talking about how hot the passenger floor area gets. However the 2V V-10 has plenty of grunt for moving around a Class C at better than highway speeds.
2006 Ford F-250 XL V-10 6-Speed
2006 Ford F-150 Crew Cab XLT
2005 Lincoln LS Sport
2003 Expedition Eddie B 4x4
2003 F-450 Lariat 4x4 Crew Cab 5-speed auto..SWEET
2005 Jayco 31' Class C on a E-450 v-10 chassis
1997 Travel Supreme 40' triple slide 5th wheel
100 +or- head of Texas Longhorn Cattle...Longhorn is the healtiest beef around.....check it out.
NEED BEEF give it a try?
So what year did the 3v V-10 start? Which one would a 2001 V-10 excursion have and what would the HP be? I'm new to this gasser stuff.
Thanks,
TheBlueMule
1989 F-350 crew cab dually 4x4 7.3 IDI, Banks Sidewinder Wastegated Turbo. Rebuilt E4OD with Transcommand. push button start, 5" straight piped dual bullhorn stacks. New body work and paint. Custom diamond plate interior. Custom built front and rear HEAVY DUTY bumpers, Many Many Mods on the way. Just need more money and time. [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img] fuzzy dice hangin from the mirrior
1990 F-350 Crew Cab SRW 7.3 IDI with ATS turbo. Offroad wheels and tires. E4OD. custom exhaust and turned up pump. New bed and paint.
