disappearing oil? - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 06-30-2009, 10:49 PM   #16 (permalink)
hco4x4's Avatar
i noticed today the crack sensor plug had fallen off. after i put it on it started right up. i still dont know where the oil went though.
hco4x4 is offline
Old 07-10-2009, 12:25 PM   #17 (permalink)
Could the oil be getting into the cooling system ?
Sold - 2000 F250 extended cab 2wd XLT, V10, automatic
Looking for an older extended cab PSD.
westport is offline
Old 07-10-2009, 01:23 PM   #18 (permalink)
FryerJim's Avatar
Let me check the numbers I am hearing...
6 quarts in when you built and installed the engine.
3 quarts when it died at the green light
5 quarts after you got it back from the mechanics.
Nowhere have I heard you say that you started out with 15 quarts in the engine to begin with.
If the numbers above are the only oil you have added then you are just now at the bottom end of the OK range. (6 + 3 + 5 = 14 quarts)
I'm sure I'm misunderstanding what you are saying, but that is what I get from reading your posts.
99.5 and up 7.3s hold 15 quarts. Is that 15 quarts plus the total of 3 that are up in the oil galleries and the HPOP?
-Jim
Early 1999 F350 6sp Manual, CC, Dually, Long bed, 2WD, 3.73 rear end.
Almost stock, PO dualed the exhaust out after the rear axel.
Purchased 3 April 2009 with 122,500 miles on it.
9 June 2009 has 127,000 miles on it.
Mods to come later...
FryerJim is offline
Old 07-10-2009, 01:36 PM   #19 (permalink)
bugman's Avatar
My Photos: (18)
-Jim
You may be a little lost since you are posting in the gas engine forum and not a diesel forum. It also doesn't look like you started to read from the first post since the first sentence says "i have a 99.5 v8 5.4" The gas engines do not hold 15 quarts.
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 07-10-2009, 02:27 PM   #20 (permalink)
FryerJim's Avatar
Red face
Man, I have to learn to lay off the crack!!!
I knew I was missing something! I just figured that it was that he filled it with oil to start with, not that I had the completely wrong engine type in my head.
My apologies!
-Jim
FryerJim is offline
Old 07-10-2009, 10:32 PM   #21 (permalink)
hco4x4's Avatar
that doesn't help me much lol well an update for ya. i put in a quart of stop leak and 2 quart of oil about 200 miles ago and haven't lost a drop since. this **** confuses the hell outa me
hco4x4 is offline
