Does anyone know how to adjust this bar correctly?
Will an alignment shop be able to check this for me or are they going know how to adjust it?
I ask this question because I just installed one and everything appears to be ok, but I want to be sure that I am not going down the road crab style if you know what I mean. [img]/ubbthreads/images/graemlins/eek.gif[/img]
Thanks !
<font color="purple">2002 F-350 Crew Cab, Lariat, 4 x 4 Off Road, <font color="red">V-10</font>, A/T, 4:30's, Snow Plow Package X-Springs, Lighted Heated TT Mirrors, Reverse Sensor, Alarm-Remote Start, Husky Floor Mats, Silverstars, Garmin GPS V, Jack-It Lift, BFG 35's w/ 16 x 10 wheels, Rancho 9000X Shocks, TruSpeed, Berlin Bed Cover, Fireman LED lite bar..and a partridge in a pear tree</font>
<font color="blue">There are two rules to success in life: 1. Don't tell people everything you know.....
2000 F-350 XLT CC SRW 4x4 LWB V10 Auto 4.30LS. 10.5" lift, 39.5" Swamper TSL's and Dynatrac combo kit. click here for pics</font color>
Thanks for the help, but I don't think we followed the instructions like the link you provided says. I am wondering if there is a way to check if the adjustment are correct. We basically yanked the old one and then lined up the new one allowing for the added lift.
Appreciate any input on this [img]/ubbthreads/images/graemlins/confused.gif[/img]
Thanks !
Do what Keithf said and make sure the axle is centered. The Fabtech instructions say to torque the bolts to 110 ft lbs, but I had to do at least twice that to keep the trackbar from popping.
Try this:
Leave the vehicle's weight on it's front axle i.e. do not jack it up.
Take a nut off either of the track bar bolts.
Try to remove the bolt.
If the bolt can be removed with minimal effort then the track bar is at the right length.
If the bolt has to be hammered out with a drift/etc then you need to adjust i.e. lengthen or shorten the track bar until the bolt can be easily inserted/removed.
Hope this helps!. Keith.
I will try the method that you suggested KeithF, I finally understand the theory behind this now...lol...took me long enough. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Stan thanks for the advice as well [img]/ubbthreads/images/graemlins/smile.gif[/img]
