Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Gas Engines
Gas Engines Discussion of the gas engines available in the 1999-2007 Super Duty trucks
Old 06-24-2005, 05:20 PM   #1 (permalink)
Fuel filter replacement??
How does one change the fuel filter on an F150 2001? Is there web site that shows step by step? Seems Diesel is so much easier but since Ford want to charge me $75 to do it I tought I woould ask.
[color:"blue"]2001 Silver F250SD PSD 4X4 (ACQUIRED 03/09/01)Tow Pkg, Camper Pkg, Off Road pkg, Husky Liners, Quantam Tinting, Duralast Gold, 35/12.5R16 Toyo M/T, 6" Lift, Fumoto Valve, MBRP 4" TB, Coolant Filter, 203* Thermostat, AFE Stage II w/ Pro Gaurd, 08 Diff Cover[/color]
Caladin is offline
Old 06-26-2005, 04:55 PM   #2 (permalink)
Re: Fuel filter replacement??
Fuel Filter Replacement Instructions
Contributed by Michael Kisielewski
Tools needed: Fuel Line Disconnect Tool
After leaving the truck sit over night, I relieved the pressure in the fuel line using the schrader valve (tire valve) which is located on the top of the fuel rail on the passenger side of the engine on my 4.6L. I was prepared for some fuel leakage with a rag wrapped at the base of the valve. I removed the plastic cap and used a small nail to push the valve in. There was only a small release of pressure, I suspect because the truck had sat overnight. With the pressure released I replaced the cap on the valve.
As a precaution I than removed the fuel pump fuse, (position number 19) in the "Power Distribution Box" which is located on the driver's side of the engine compartment behind the air filter housing.
Next, locate the fuel filter which can be found inside the frame rail on the drivers side approximately 4 to 5 feet back from the rear of the front tire. It's a silver metal canister approximately 2 and ¾ inches in length.
To remove the lines you take the fuel line disconnect tool and place it on the fuel filter where the fuel line connects. Push the tool so it slides inside the fuel line releasing the internal clips that lock it onto the filter. Once the tool is inserted completely inside you should be able to pull the line off the end of the filter. Repeat this for the other end.
Once the lines are removed cap off the ends of the filter to minimize fuel from spilling out while removing it from the bracket.
To remove the filter from the bracket I found it best to hold onto the ends of the filter while pushing the filter up and rolling the bottom of the filter out of the bracket.
Once the old filter is removed install the new filter into the bracket making sure the flow direction is correct. With the filter installed push the fuel lines on the appropriate ends until you hear a click. That will be the clips inside the line locking onto the filter. With your lines connected replace the fuel pump fuse. Put your key in the ignition and turn it to the on position and check to make sure there are no leaks.
Caladin is offline
Old 07-09-2005, 10:21 AM   #3 (permalink)
SUPERDUTYAZ's Avatar
I did mine last night.So easy I should have did it along time ago.I bought a tool at Checker for 12 dollars.The hardest part was getting the filter out of the bracket,MD
2002 F250 V-10 CC SB 4X4 AUTO 4.30LS OFF ROAD PACKAGE,DIXON BROTHERS RACING PREUNNER BAR,2007 GRILLE & HEADLAMPS,CHROME EMBLEM MOD, HOME MADE MESH CAB MARKER LIGHTS, HELLA AIR HORNS, PINCH WELD HOLE COVERS, WHITE EXCURSION DOOR HANDLES, LIGHT FORCE OFF_ROAD LIGHTING ,HOMEMADE AIR INTAKE,TRUESPEED,PACIFIC TRUCK EQUIPMENT UTILITY BODY
BF GOODRICH 37x12.50XR17 ALL TERRAIN T/A's
OFF ROAD WAREHOUSE
SUPERDUTYAZ TRUCK PICTURES
SUPERDUTYAZ is offline
