Gas gauge problem! - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 12-07-2000, 08:13 PM   #1 (permalink)
Gas gauge problem!
Does your truck do this like my new cc? When I was driving on the level the gas gauge was just under full, I went up a pass not too steep and didn't notice anything but when I went down the other side the gauge went down to 3/4. Driving around town it was on 1/2 and when I drove back up the pass later the gauge went up to 3/4! Is this normal? How can it be fixed?
2001 F250 CC XLT 4x4 V10
Auto Shortie 3:73LS Red Loaded
iweb is offline
Old 12-07-2000, 10:51 PM   #2 (permalink)
Re: Gas gauge problem!
Something similar happens to me...my driveway goes uphill, and if I park with the truck facing uphill, in the morning when I start the truck, my gas gauge will say 1/2 and then on my way to work it goes down by 1/8. If I park the truck facing downhill, it will say 1/2, and then on the way to work it will gain 1/8.
The same thing happened on my '99 F-250 V10, and I just ignored it...
2000, F-350, XLT, SC, V10, 5 spd, 4x4, 4.30LS, Short Bed, Off Road Pkg, Camper Pkg, Silver Frost, F550 "X" Springs...etc.
2000, F-350, SRW, XLT, SC, V10, 5 spd, 4x4, 4.30LS, Short Bed, Off Road Pkg, Camper Pkg, Silver Frost, F550 X Springs, Fabtech Dual Front Shock Kit, with Trailmaster SSV Shocks, Trailmaster SSV Steering Stabilizer, SuperChip, Banks Stinger Cat-Back Exhaust, Borla Headers, K&N Air Filter, Sony CDX-MP450X MP3 player, Infinity reference speakers x 4, Sony Xplod 75W x 4 Amp, Sony 12 Subs x 2, custom sub box...etc.
F350V10 is offline
Old 12-07-2000, 11:48 PM   #3 (permalink)
Unfortunately, what you describe is "normal". My guess is that the fluctuation is the result of a long-skinny fuel tank. Fuel runs to one end or the other causing the guage to over-react.
NoMo's website
NoMo is offline
Old 12-08-2000, 04:25 AM   #4 (permalink)
Normal.. I have the same driveway as 350V10. Does the same thing.
2005 V10, AT, Fx4 Dark Stone Metalic, Crewcab F350, 4.10LS, shortbed, towcomand, Extang tonno **SOLD**
2007 Dodge 3500 Quadcab, 4x2, 6.7L Cummins, a/t, longbed, 4x2
Silence is golden. Duct tape is silver.
V10 man is offline
Old 12-08-2000, 08:03 AM   #5 (permalink)
Same thing.
crewzer -- Y2K F250 SD 4X2 CC SB XLT 5.4LV8 AT 4.10LS
crewzer is offline
Old 12-09-2000, 12:51 AM   #6 (permalink)
wldwilliam's Avatar
same here...same driveway...
takes forever to return to the actual reading...causes problems when getting close to fill-up time. "I can make it, the needle's above the E"...2 miles later, "Holy Cr*p!, it's below E now!" [frantically scanning the corners for any sign of a gas pump]
2005 F350 | Lariat | CrewCab | 4x4 | 6.0 | 5 spd auto
Edge Insight & ScanGauge II monitors | Autometer FP gauge | DieselSite Coolant Filter | DR 2.5" level
18x10 Weld Evo Cheyenne 8 | 325/60r18 ProComp XAT | Upfitter Switches added | Extang Trifecta Tonno
Amp Research PwrStp | high idle mod | Ford F/P reg mod | latest EGR valve
03/06, 9K miles
oil leaks (r&r rear main seal and cam sensor), recall 05E16 (ECM recalibration), recall 05B32 (de-gas bottle fill level label applied & coolant level adjusted)
06/07, 22.5K miles
no 4x4 (r&r left side vacuum hose), e-brake malfunction (r&r parking brake ratchet assembly)
01/10, 30K miles
oil leaks (r&r bed plate, rear main, rear cover gaskets & o rings), CEL (r&r reman turbo, drain tube, update processors)
03/10, 30.5K miles
EOT +15°>ECT (r&r oil cooler, egr cooler, degas bottle & cap)
[all under warranty]
wldwilliam is offline
Old 12-14-2000, 06:54 PM   #7 (permalink)
My Photos: (9)
Had the same problem. Took it to the dealer, and they dropped the tank and changed the sending unit. No problems since.
2005 - F-350, PSD, LWB, FX4, KR, Oxford White/Arizona Beige -- Bausch & Loam Sunglasses
My Photos -
SOLD - 2001, F-350, PSD Lariet, Oxford White, CC, LWB, DRW; [color = red]Maghytec Transmission Pan and Differiential Cover[/color]; Autometer Bezel; [color = blue] SPA Boost/EGT, Transmission and Differiential gauges[/color]; Ford Bug Shield; WeatherTech Rain Guard; Pioneer 6 disc changer; Ford Rubber mats; Cobra 29WXNWST CB Radio; Cobra CA 77 Power microphone; Husky Molded Flaps and floor mats. [color = green]Banks Power Pack[/color]. J&J Stainless Steel Running Boards. J&J Victory tail gate. Bilstein shocks. [color = red] 2003 heated TT Mirrors - with rear window defogger switch. [color = red ] C-Betr Mirrors. NMC2. .[color:"red"]SoCAPS Member[/color] [color = green] SoCaps Founding Member [/color]
Aaron Ruble is offline
Old 12-14-2000, 08:09 PM   #8 (permalink)
You do not know how irate this gas guage get me.
2000 F250, XLT, Silver, F550 X Springs, SC, V-10, 3.73LS, 4x4, SWB, Bug Shield, Vent Visors, Rhino Liner, Hyperwhite Bulbs, PIAA 1100x Super white fog lights.
(YOUNGEST SUPER DUTY V10 OWNER @18)
Click here to see the hottest rig in NJ [img]/ubbthreads/images/graemlins/wink.gif[/img]
V--10 Power is offline
