I have a 00' F250 Crew S/B with the V-10, Auto, 4.30LS 4x4. I carrier on vacation a Lance shelf contained camper made for the short bed. Trouble is no range with getting only about 6-7MPG. Any suggestions on what can REALLY help the mileage issue
If you've been lurking here since April 2000, you know the answer is Nothing. Chip, exhaust, zoodad, etc. won't get you but maybe 1-2MPG at most. Maybe you should get a larger tank? Transfer Flow makes great tanks, but there's some problems with the replacement tank on CA emissions vehicles. Maybe a bed tank, uh, a camper tank? Or just squeeze in 4 more gallons when you fill up.
Unfortunately, kenc is right. There's not much you can do to improve your mileage by more than 1-2 mph. I'm surprised you're only getting 6-7 though. I would have expected more than that even with the camper and the 4.30 gears. Although I hate to say it, if you really want better mileage you should probably consider trading in for the PSD. [img]images/icons/smile.gif[/img]
__________________ Gig 'Em!! Official Member of the NRA, Texas A&M Association of Former Students, Bass Angler Sportsman Society, and the Associated Bilge Rats of the Other Forum
I'm really surprised by your mileage (or lack of it). Mine is a 4x4 with 3.73 gears and I got 10.8 mpg repeatedly with my Lance model #1121 (much larger than yours)!!! And that is running at 5000' elevation. The WORST I got was 8.8 and that was into HEAVY 30-40 mph headwinds.
What speed are you running? I think if you just slow down, the 4.30's won't be revving as high and the wind aerodynamics are less resistant. I usually cruise around 62 mph with the camper. Just try going 55-60 and see what happens...if you really want better mileage that is [img]images/icons/wink.gif[/img]
Y2k F350, white with harvest gold trim,V10,4x4,Lariat,SC,Auto,Tow pkg,camper pkg,ESOF, so-called limited slip, off road,3.73,Rancho 9000 w/ in cab control, Ride Rite Air Bags,Long bed,Rickson 19.5" wheels, Michelin XDE-MS,Lance Camper, BugDeflector2, Stull Grill, KN., Flowmaster 50
Just have to add my two bits to the V-10 with Camper and mileage. I just returned from Lake Mead Nevada to my home Stanley Idaho. 700 miles each way with a Northland 990 Camper and a 16 foot runabout Boat in tow. My Truck is a Y2k F250 4x4 Supercab Manual 5 speed with 3.73's. Have only added the K&N Filter Charger and the Throttle Body Spacer, Synthetic 5-30 Oil followed by removal of the lead from my foot. Checked every fill up on the trip while never varying from 60mph. Mileage was 12.3 average over the trip with a low of 10.9 and most fills at 12-12.8 best. Also I do drive with a Vaccum Guage to help keep the mileage up.
2000 F250 Supercab XLT V-10 4x4 Deep Wedgewood Blue,5 speed,3.73LS,6 way power Captains Chairs,Camper Package,Trailer package,Custom Wide Rear Slider Window,BF Goodrich All Season TA M/S Tires, X-Code Springs,Dayton 3,000lb additional progressive overload springs,Rancho 9000 adjustable shocks,K&N FIPK,Cool Air Intake in front of the K&N,Power Aid Throttle Body Spacer,Performance Module Computer by Diesel Chips,Engine Preluber,Ammsoil Synthetics,BriteBox Headlights, Ford/HELLA Fog Light Kit,Auto Gauge Vaccum Guage,Line-X Bedliner,XM Delphi Radio,Heavy Duty Headlight Wiring by Suvlights, Warn Transformer Bumper, ScanGuage II...almost full time carrying a Northland 990 Camper with Slide Out.
Just filled up after a weekend camping trip- first tow with new truck. About 150 miles total with the last half pulling 65-70 mph into a constant 30mph (gusting to 50) headwind (I sure hate the wind). Anyway, mileage was only 7.4 [img]images/icons/shocked.gif[/img] with OD turned off. Truck just rolled over 1000 miles tonight, so I hope things get a "little" better once break-in is complete. Then again, pulling a 8'x12'x26' 7000# "sail" into a hurricane isn't ever going to be economical. [img]images/icons/laugh.gif[/img]
when I owned a v10 I noticed a jump in mileage at 10k miles. Wow [img]images/icons/shocked.gif[/img] never would have thought I would have had to wait that long for a break in. It was after a 2500 mile trip pulling 6000lbs. Soon after I noticed a 2 mile per gallon increse from 10mpg to 12mpg. I too had the 4:30 gears and a 4x4 250 crew. Pulling I got anywhere from 7-10mpg
01 250 crew 4x4 psd auto
00 X v-10 auto
That mileage seems way too low. I get horrible mileage around town in my truck and it's not that bad. Carrying my camper on the highway, I get 9-10 mpg. I've experimented with speed vs mileage and can tell you that your mileage will drop considerably the faster you go. A camper may not be much weight, but it has the aerodynamics of a brick.
Some other things to consider is that mileage does seem to go up as the engine gets broken in. I've had 2 Super Duties now and noticed improvement with both. Also, around here they sell winter blend fuel that really drops the mileage.
Y2K F350 CC DRW LWB 4x4 Lariat 4R100 V10 4.30ls.
98 Alpenlite Pendelton 11'10 slide-in camper.
Remove I_HATE_SPAM_ from email address to email me.
TruckFreak
Here's the latest on the mileage report. Just got back from towing my 16' boat over 2 mountain ranges (two 4000 foot summits). Total trip was 260 miles and speed was around 60 +/- mph. I also motored back and forth 1/4 mile every morning and afternoon to the boat dock and back with the fishing gear. I just filled up and got 12.8 mpg. (check my sig with 4x4, auto, etc.)
It is true that mpg improves as these trucks get miles on them. Mine has 6700 miles on it now, and I noticed a 1/2 mpg improvement at 5000 in "in-town" driving.
I'll ditto the comments about the gas mileage getting better as you start putting some miles on these trucks. I noticed that when I hit about 12,000 to 15,000 miles on my truck the average mileage increased 1 to 2 miles per gallon. I have a 2001 F250 Supercab 4X4 with the 5.4 V8 for a work truck. I just turned over 6000 miles on it and my gas mileage is starting to get up around 12 mpg from around 10 mpg when I first got it. Sure is nice having 2 Superduty trucks sitting in the driveway! [img]images/icons/smile.gif[/img]
2000 F350 4X4 Crew Cab. XLT Lariat. Short Bed. V10 Gasser. Automatic. 3.73 Rear End. Snug Top Canopy. Bed Rug.
I just returned home from a weekend in the Smokies with the family.. When i first got on I-40 west I got in line with a convoy of sports cars running about 85 mph. I laid in right behind and set the cruise. 3 hours later when I reached my destination, i was in front. they were sucking gas at 9000 rpm's and my superduty gained alot of respect from them. I taveled 290 miles on 21.8 gallons of gas so you do the math..13.3 mpg.. I just turned 3000 miles on the trip home. not pulling anything but the family but remember this is a heavy truck.. Need I say more... I LOVE MY V10..... [img]images/icons/smile.gif[/img] [img]images/icons/cool.gif[/img] [img]images/icons/smile.gif[/img] [img]images/icons/smile.gif[/img]
2001 F250 CC XLT 4X4 V10 3.73LS TRUEBLUE:
1986 F250 4x4 reg.cab long bed 285's
1971 F100 short box 390V8 hoss.
2000 Yamaha YZ 426,
1987 Yellowstone TT 21'
Add-on's: Clear marker lights, chrome fender trim,chrome bed rails, Jack-It leveling kit, cab clearance lights, tinted windows, stainless billet grill,K&N air filter,BFG ko's 35x12.50x16.5 on 9.75x16.5 pacer's
I have been getting 10.9 mpg around town. The truck had 22.5k miles on it when I bought it two weeks ago. Just put a rollnlock bedcover on it last weekend and will be driving to Albuquerque this coming weekend. It will be interesting to see how it does on fuel. I wish I had taken a road trip before I installed the bed cover to see if there was any improvement.
Will post mileage Sunday night when I get back, it is 245 miles each way to Alb. from here.
99.5, F250, CC, XLT, 4x4, V10, Auto,Off Road Pkg, Dark Tourmaline, 4" BDS lift, 315/75/16 Durango AT, Eagle 16x10, light tan interior, 6-way Power Seat, Chrome Grill Insert, Clearance Lights, 3.73, LS, Roll-n-Lock bed cover, driving lights photos
Without trying to get things stirred up, if you were really worried about mileage, you should of got the PSD.
2000 Lariat 4x4 F350 Crew Cab SRW 7.3L PSD Long Bed Woodland Green/Harvest Gold ,Auto, 3.73, TT, Stockland Sebring Canopy: MILEAGE 21@ 65mph 19@ 72 mph, 15.8 in City.
2006 Nissan Armada LE, all options available from nissan its has, tech package, dvd etc etc etc. Runs like a bat out of hell. Amazing motor.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Matt Nelson: Without trying to get things stirred up, if you were really worried about mileage, you should of got the PSD.<HR></BLOCKQUOTE>
Matt, I think that comment was rather unnecessary. Us folks who buy the V10 do not want to spend the extra $4000 to buy a PSD. The extra cost on a payment is reason enough. It takes a looooonnngggg time to recoup that money in gas savings when you add up the total cost of ownership of the two vehicles.
Now, does that mean that we can't find way's to improve mileage? Anyone that buys a V10 does not consider fuel mileage the most important thing, but that doesn't mean we can't or shouldn't find ways to improve it. Enough with the 'you should have bought a PSD' comments please!!!!!!
2001 F-250 SC SB 4x4 V10 Lariat, Black with Harvest Gold Tutone
heated leather captains, 3.73 trac lok, power TT mirrors, 6 disk in dash CD, roof lights, camper package, custom subwoofer box w/2 8 subs, Access roll-up tonneau cover, BFG 285's....etc
With Diesel at 1.45 a gallon and regular unled at 1.75 agallon. 10 mpg vs. 18 mpg doesn't really take that long to recoup the extra money, especially when resale time comes around.
Just my $.02
Rebel
01' BRIGHT RED PSD CC Shorty 6-SPD 4x4 XLT Parchment Int. Billet Grill & Warn Transformer w/ winch. Superchips programmer, Airaid, and custom 4" dual exhaust.
