Re: Gas mileage on a f350 V10 4.3 and more
(corrected, now that I see you're asking about a DRW [img]images/icons/frown.gif[/img] )
EMH,
Ford's tow guide says the 350 RC 4X2 DRW V10 AT 4.30 has GCWR of 20K lbs. and can tow a "maximum" 5er trailer of 14,100 lbs. Allowing for a 150 lb driver, that suggests the stripped (XL trim) truck's curb weight is 5,750 lbs.
My guess is the RC truck's curb weight will be closer to 6,000 lbs or so, and, once you add a hitch, yourself, another passenger and some other "stuff", the truck'll weigh in at around 6,800 to 7,000 lbs.
The SC will add another 300 lbs or so.
With a 11,500 lb GVWR and a 20K GCWR, the numbers suggest you'll be *just* OK towing a 13K trailer; the pin weight won't be an issue. However, Ford's tow ratings for gas powered trucks are based on sea level operation, and the GCWR should be derated by 2% for every 1,000 ft gain in elevation.
I'm considering such a combination down the line a bit. However, since I'm liable to want to tour in the Rockies, I'll probably go with a PSD (an extra 500 lbs) and the SC, so, going by the book, I'll probably be looking at a trailer at 12K lbs or less.
In your situation, it might be worth looking at the F450 with the V10 and 4.88 axle. It's GCWR is 24K
HTH,
crewzer
crewzer -- Y2K F250 SD 4X2 CC SB XLT 5.4LV8 AT 4.10LS
