Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Gas Engines
Gas Engines Discussion of the gas engines available in the 1999-2007 Super Duty trucks
Old 11-01-2000, 01:12 PM   #1 (permalink)
Re: Gauges
I installed transmission temperature, oil pressure, and water temperature.
http://www.eurekaboy.com/apillar.htm
www.eurekaboy.com/f250.htm
Stan Wright is offline
Old 11-01-2000, 01:31 PM   #2 (permalink)
Re: Gauges
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by acn:
I'm just wondering what gauges people have been adding for their gas engines. I'm sure I want a vacuum gauge, but I'm not sure what else would be useful. The only other things I could come up with would be coolant temp and oil pressure (since someone said those were dummy gauges anyway).
- Alex
<HR></BLOCKQUOTE>
I did some testing on my Excursion gauges recently: http://forums.ford-diesel.com:8080/u...ML/002175.html
to evaluate upgrading the pressure gauge to analog.
You are correct, the pressure gauge gives 'digital' information, even though the gauge itself is analog. However, it was determined that the temperature gauge is indeed analog. Watch your temperature gauge before you start your engine (when cold). Then watch the gauge rise as it warms up.
I am going to install a temperature and voltmeter gauge. I did not test to see if the volt gauge was analog, but I'm not satisfied with the resolution of the OEM anyway.
Personally, I beleive the look of the pod / pillar mounted gauges is worth new gauges anyway.
When you buy gauges, keep in mind that some gauges are available in electrical or mechanical. For instance, a mechanical pressure gauge will require you to run an oil tube to the gauges (inside the car). Personally, I prefer to go all electric (where possible) to keep all the liquids out of the inside of the vehicle.
Another thing I've never seen discussed here is adding a connector to all wires at the pod. I personally am going to install small molex connectors at the pod so that I could easily remove the gauge pillar and gauges if necessary. Note, you can't do this for a temperature gauge that runs the thermocouple wires all the way to the gauge. Those are not slicable. However, most temperature gauges run a voltage sensor output wire, and not a thermocouple wire.
There is an article in the general area of this forum, that discusses the installation of different after market products on this site's 'Project Truck'. One section has a very good article on a pillar gauge installation. For instance, he indicates the ISSOPRO? gauge back lighting is a bit too bright. He indicates he replaced the existing bulbs with a 194? and it provides lighting equivalent the existing truck lighting.
I purchased my pillar mount and Autometer gauges from Diesel Injection Service.
I personally would be interested in someone doing a detailed report on installing the aftermarket sensors. For instance, teeing in to the existing pressure sensor.
2000 Excursion XLT 4x2, Toreador Red, Craftsman Tool Chest (14x28x28 opp sp Tire), autodash.com Trim
MGiles is offline
Old 11-01-2000, 03:42 PM   #3 (permalink)
Re: Gauges
MGiles,
Click on my above 'apillar' link. I have pictures and commentary on installing the senders for the guages.
Old 11-02-2000, 12:49 AM   #4 (permalink)
acn
Gauges
I'm just wondering what gauges people have been adding for their gas engines. I'm sure I want a vacuum gauge, but I'm not sure what else would be useful. The only other things I could come up with would be coolant temp and oil pressure (since someone said those were dummy gauges anyway). Any other ideas. I'm not going to be towing very often.
- Alex
2001 F250 4x4 XLT, SWB S/C, Black, V10 5-spd, 4.30 ltd slip, Snow plow/off-road Pkgs, LT265
Ordered: 04OCT00 Scheduled Build: 06Nov00
Line-X, Access Roll-up Tonneau Cover, Pro-Flaps, ID lights
Some Old Pictures
acn is offline
Old 11-02-2000, 08:18 AM   #5 (permalink)
Re: Gauges
Tranny temp gauge for sure. Look at this:
http://albums.photopoint.com/j/Album...3146&a=4739786
2001 F-350 SuperCrewzer, Crew Cab Dualy LB XLT, 7.3L PSD, 4.10 LS, Oxford White w/ Silver lower tone, Med Grey interior, Power 40/20/40, Auto w/ Dacco Super Hauler TC and Magnafine, Towing Pkg w/ Dual Alts, Ford AIC, Prodigy, Gentex Mirror, Cobra 29WXNWST, 5ft Firestik II, X Monitor, Baldwin Coolant Filter, Sony OH Video system, Yakima Racks and basket, 45 gal auxiliary tank and 12V Pump, Towing a 26 Foot Prowler Lite.
http://www.cphilip.com
cphilip is offline
Old 11-02-2000, 08:45 AM   #6 (permalink)
acn
Re: Gauges
Is tranny temp as important with a manual? I thought those were only really needed on auto's since they tend to overheat more while towing.
- Alex
Some Old Pictures
acn is offline
Old 11-02-2000, 01:00 PM   #7 (permalink)
Re: Gauges
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Stan Wright:
MGiles,
<HR></BLOCKQUOTE>
Yes, that will help when I get ready.
My gauges fit very tight in the Tri-pillar openings. However, they tend to work their way out about 1/2 inch after I let go. Did you have this problem. And did you use anything to hold the gauges in the holes. Mine came with a 1/2 wide black rubber band, but that wouldn't stop them, from backing out.
MGiles is offline
Old 11-02-2000, 02:44 PM   #8 (permalink)
Re: Gauges
No, I haven't had any problems with the guages working their way out. I filed my holes so that they fit snugly, but loose enough so I could rotate them and pull them out if I needed to. I didn't use any brackets to hold them in.
The wiring isn't bunching up against the factory trim piece and pushing the guages out, is it? That's the only thing I can think of.
