i got an 00 and an 05 they are at difrent rpms at the same speed did the 00's come with lower gears?
i looked on the door tags and i think the 05 has 383's but could not find the code on the door of the 00?
97 crew cab short box f250 power stroke 4x4 automatic. 4.10s a stock other an 209500 miles first tank 18mpg, 4in exaust with no muffler now.
1983 F-350 Crew cab 4x4 4.10 5 speed 90 cummins 12v, turned up pump, centerforce clutch, stright piped,97 alcoa ford wheels, with custom built flatbed 265 85 16s
sold!!!! 96 crew cab short box f250 power stroke 4x4 automatic. 4.10s one wheel wonder 180000 miles, old chip no epv 3in down pipe, 5" STACK custom air cleaner (like tymar) custom bumper 285 85 16's
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Magnaflow, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i, MagHytec rear dif cover.
2007 Lincoln LT (wifer's grocery getter),Superchip,Magnaflow duels, K&N dropin, Leer Browning Special
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies. pappy's truck
It is has been awhile but has Ford removed the tag on the rear hosing cover? Take a look down there at the cover, Ford "was" good at putting the gear number in real (no code) numbers on that tag.
EDIT... Now that I think of it, that was limit slip rears (i think), worth a look in any case.
*I am Fordless, SOLD* 1999 F350 XLT 7.3 SD SC DRW 4:10 LS Auto Trans 4x4 Auto Hubs APC Telescoppic Heated Power Tow Mirrors K&N Filter Banks 3 1/2 down pipe ATS 4" exhaust 3 gauge (ET, trans temp, turbo boost) pillar mount WD Chip WD Turbo Brake
yea i ment 373 not 83. the 00 is about 400 rpm higher than the 05?
are there difrences in the final ratio in the trannys then? the 00 runs 400 rpms higher than the 05 at the same speed?
My excursion came with 4.30 limited slip from the factory (said it right on the diff tag), I believe standard they came with 3.73 and the optional gear was 4.30.
2001 Excursion 4x4 Limited v10, Estate green, 4.30 LS
Bull bar, 150w KCs, clear corners, bed liner on bumpers and lower trim, zoodad mod, v-code front springs, acetoned emblems, deleted running boards, in channel vent visors, 285/75/16s, all green in-cab lights changed to orange, gutted cat and SuperTrapp muffler w/10 discs exiting at the diff, dome light override switch, 3 ga pillar mount *sold*
