Getting tired of having to baby the final 5 gallons in.......
Of the two major complaints with my new truck, the most annoying is what a PITA it is to fill up the tank until it's full. I am not bringing it to the dealer unless I know there is a fix that they know of. Has anyone gotten anywhere with their dealer on this?
2001 F-250 SC SB 4x4 V10 Lariat, Black with Harvest Gold Tutone
heated leather captains, 3.73 trac lok, power TT mirrors, 6 disk in dash CD, roof lights, camper package, custom subwoofer box w/2 8 subs, Access roll-up tonneau cover, BFG 285's....etc
Re: Getting tired of having to baby the final 5 gallons in.......
After I heard about this problem with others on this forum, I filled up my gas tank as usual. After the pump shut off normally, I kept filling the tank. Very soon I was rewarded with gas coming back out of the tank onto my shirt [img]images/icons/mad.gif[/img] Anyway, I certainly don't have this problem! [img]images/icons/smile.gif[/img]
'00 F250 SD V10, CC, 4WD, SRW, LB, 4.3LS, 5-spd manual, 5.5 Fabtech lift, 35 BFG AT KO tires, Rancho 9000 shocks (dual in front), Velvet rides, Line-X, Pilot backup lights, cool stickers :-)
Perfect example tonight. I ran my tank farely dry, and the pump first clicked at 23 gallons. Again, I had to 'feather' the pump to get the additional 5 gallons in.
V10man, it appears as if this problem is more prevalent on the SB's, and not the LB's which you have. My buddy has a LB V10 and also does not have this problem.
True on the long bed thing. The pump once clicked off on me at 37.5 gallons. I new I was close but not that close. I still miss the 2 tanks with the switch on my old 150. I loved to run it dry. I know that's not good but each pump lasted 11 years!
Tony, I've found that I can get the rated 29 gallons in my short bed version with only one click of the pump IF I do not push the nossle in all the way. I actually keep it out about 3 or 4 inches. We have the gass recovery spring-loaded nossles here, and it is a little bit of a pain, but it is much better than babying the last 5 gallons. I also experimented and found that I can put about 31 or 32 gallons in if I keep going to the top. (I ran my truck almost dry while carrying a gas can in the bed to experiment.)
'01 White/grey F-350 4x4 XLT, V-10, SC, shorty, 3.73LS, Tow Mirr, slide glass/pvcy, clearance lights, camper pkg, off-road pkg, Street Scene grill insert, Sport Masters Hinged Slantside Tonneau, Tork Lift frame-mnt camper tie-downs, soon-to-be: Lance Lite 845 camper.
Don, that's a great suggestion and I have actually tried that to no avail. No matter how fast or slow I pump the gas, the damn thing will always click at 23-24 gallons, and then I painfully have to get the last 4-5 gallons in. The gas tank appears to not be vented properly, and it is very annoying!!!
Tony, how far are you letting the fuel guage go down? When I was doing my little experiment mentioned above, I found that I could actually drive over 50 miles after the needle read empty (I don't mean the light comes on - I can go maybe 70 miles after the light comes on.) You may not be actually using near all the gas you have. And with the extra 2 or 3 or so gallons you can stuff in the fill tube, it would add up. You ought to try running your tank empty (only once to calibrate your guage) while driving around with a gas can in your bed when you get real low. I think you'll be surprized.
don
This might sound kinda odd but, a friend of mine has an old chevy and sometimes he has to turn the nozzle upside down to stop the pump from kicking off. Maybe try that?
On a side note, I have a LB and I have no problems. I can actually get a hundred or so more miles outta a tank a gas once the light comes on. I've only ever run out of gas once. Ironically it was right after I started the truck up to go get gas and I didn't even make it out of the driveway. [img]images/icons/laugh.gif[/img]
Try filling up at a pump that is not on a level surface, and fill up with the truck running down hill. This fills the tank as full as possible without the shut-off problem [img]images/icons/smile.gif[/img]
99, F250, SD, XLT, CC, 5.4L, 3.73, TT MIRRORS, K&N, RANCH HAND GRILL GAURD, SONNAX VALVE & TRICUMULATER SPRING SET, RHINO-LINED, MOBIL 1 SYNTHETIC THROUGHOUT, MER4 PCM
Tony
My SB 29 gal is only a couple of months old. I have same prob as you. I carry a small ramp I made out of cedar stump and chain saw 8"X8"X 24". If the right side or front is higher (even a little) she won't fill that last 4-5 gal. Left rear wheel on the block/ramp and it fill to the brim every time on full flow, one click and done [img]images/icons/laugh.gif[/img] Of course I do get the folks at the pump looking at me like I'm nuts [img]images/icons/cool.gif[/img] but at least the minute it takes is shorter than the extra five min to top off [img]images/icons/wink.gif[/img]
BTW I plan to replace the Ford tank with larger in same place... When I do the mod I will ask the folks at AREO if they can place several purge vents so I won't have this problem X 55Gal
White 05 F350 King Ranch 3 valve V10 5R110 Auto 4.30:1LS 4x4 LWB SRW born on 3 Sept 04
