Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Gas Engines
Gas Engines Discussion of the gas engines available in the 1999-2007 Super Duty trucks
Old 12-13-2002, 07:03 PM   #1 (permalink)
Has anyone done this "A/C mod" on their V-10?
Here is the gadget. I see no reason why it wouldn't work, it is just listed as for the Powerstroke and I was wondering about installation procedures/instructions. Any help? Thanx!
Rob
1999 F250 V10 XLT 4X4 Silver Super Cab Shorty. 6" Skyjacker, Dual Nitro shocks, 37" PJ Dirt Grips on Eagles, Rancho SS, Smittybuilt Nerf bars, Privacy Tint, Catch All floormats, HFFTTT Mirrors, Stull Grill, CL's, Blaupunkt and Pioneer, quad-gauges, CB.
bajarunner is offline
Old 12-13-2002, 09:34 PM   #2 (permalink)
Re: Has anyone done this "A/C mod" on their V-10?
Looks good to me. $25 aint bad either. I'm sure the ac system is the same for either engine. Maybe you can e-mail them and get install instructions.
2005 V10, AT, Fx4 Dark Stone Metalic, Crewcab F350, 4.10LS, shortbed, towcomand, Extang tonno **SOLD**
2007 Dodge 3500 Quadcab, 4x2, 6.7L Cummins, a/t, longbed, 4x2
Silence is golden. Duct tape is silver.
V10 man is offline
Old 12-13-2002, 11:20 PM   #3 (permalink)
bajarunner,
Here the link for the 16.00 heater bypass. I did this to my truck back in the summer and it helped out a lot. I used the bypass part from auto zone then put a tee in the white vacum line under the pass.dash so it only works when the a/c switch is in the max postion. Also the bypass they use allows the coolent still flow through engine block where as some of the other don't.
http://forums.thedieselstop.com/ubbt...art=1&vc=1
Jason
04-F350 KINGRANCH
http://WWW.IAFFLOCAL502.COM
http://WWW.APFFA.ORG
ASFFA
JCSHADOW5 is offline
Old 12-14-2002, 12:33 AM   #4 (permalink)
http://www.eurekaboy.com/f250/heaterhose.htm
Stan Wright is offline
Old 12-14-2002, 11:01 AM   #5 (permalink)
BA
If you do a search on "heater bypass" there is a member who used a 95 ranger heater valve & spliced in to the red vac. line. The hot water the goes back to the block & not thought the heater core when the a\c selector is set to A\C, Max, Vent, NO heat when set here even if you turn the temp. control, for heat you must select 1 of the options not listed above.
I did this and I like the results! [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/cool.gif[/img]
Search under username - " LOOK Repair For Hot Cab Vent Air" by superduper
<font color="blue"> F250 SD / PSD / SWB / CC / 4x4 /</font><font color="red"> Silver </font> <font color="blue"> / Med.Flint / TT Mirrors / RH Bullnose / </font> Dipricol gauges / <font color="green"> 315 BFG A/Ts </font><font color="blue">/ Bilstein shocks </font> <font color="black"> / Spray Liner </font> <font color="blue">/ Billet grille / Edge 2" Mini Spring Pack </font> <font color="orange"> /clearance lights / </font>
<font color="black"> </font> /MBRP / XM Radio / 24" wipers / PC Xtream 8085
BA is offline
Old 12-15-2002, 09:18 PM   #6 (permalink)
My Photos: (5)
Installation is a snap...takes all of 20 minutes. Spent most of the time choosing the best spot to splice the valve into. Do it with the a cold motor.
2001 F250 XLT 4X2 CC LWB, PSD, BrightRed, LineX, Banks Turbo housing with Big Head, Banks 4" Monster Exhaust with SS MagnaFlow Muffler,AFE intake, Bill's Chip 45/70/100, Transmission by John Wood, AutoMeter Ultra Lite Gauges,SnugTop Shell, AIC with ITP bracket,TTM, ProComp 6" lift w/MX6 shocks,ProComp 305/70/16 on AR Chrome Baja's,Pioneer Premier CD &12 disc changer,XM tuner, Eclipse speakers, Fosgate sub,PCM Code NMC3. Big Red F250
fyrmng is offline
Old 12-16-2002, 06:00 PM   #7 (permalink)
So you guys have seen a reduction in AC temps right? Best I can get is 50 degrees at the vents. (did hit a 48 once)
V10 man is offline
Old 12-16-2002, 06:35 PM   #8 (permalink)
V10 man,
I have'nt checked to see how cold the temp gets, but I can tell a big differance just by feeling the cold air comeing out of the vents,especially if your running down the interstate or if you leave it idleing and get back in on hot summerday mine will give you chills. [img]/ubbthreads/images/graemlins/wink.gif[/img]
Jason
04-F350 KINGRANCH
ASFFA
Old 12-17-2002, 01:11 PM   #9 (permalink)
Stan,
After looking at your pictures I took a look under the hood. I assume the hose is the one that runs from the core to the top of the right bank cylinder head. I didn't notice the return from the core (it's a little tight and I wasn't dressed for crawling around the engine this morning [img]/ubbthreads/images/graemlins/grin.gif[/img]).
I also guess guess blocking this line doesn't effect the flow of coolant. If I can't find a nice valve like yours I was thinking a CPVC ball valve from HD.
Thank for th info,
Rob
robsd is offline
Old 12-18-2002, 12:47 AM   #10 (permalink)
Correct. I unhooked the hose from the head and pulled it out. I installed the valve and ran a new piece of hose back to the cylinder head. This made the valve easy to get to, and I can put it back to stock easily if I wanted. This modification does make the A/C colder.
Old 12-18-2002, 11:22 AM   #11 (permalink)
Very interesting idea. Gets real warm (hot) here in SE Texas in the summer. My question though is by doing this mod, do we run a risk of having the evaporator coil freeze up? Maybe the warm coolant flowing through the heater core is designed to moderate the temps near the evaporator to keep it from freezing up. I don't know, I'm not an HVAC specialist but I'm just curious if this could be a problem. If this mod keeps me cooler in the summer though without causing problems...trust me, I'm ALL for it!
Tejano
2006 F-250 SD Lariat 4X4, 6.0 Liter, all stock
Tejano is offline
Old 12-18-2002, 11:44 AM   #12 (permalink)
Rob,
I installed a steam-rated ball valve (brass, I think, from HD) last summer. For summer operation, I closed the valve most of the way, but left it open just enough to let a bit of coolant circulate through the heater core.
This valve setting was subjectively determined by allowing for just the slightest increase in air temp from the dash registers with the temp contoller set at max heat.
What a difference this mod made! Last summer's western trip found us in Scottsbluff, NE where it was 113 degrees, but the modified AC, running on 'Normal' and not 'Max', kept our crewcab cool and comfy. [img]/ubbthreads/images/graemlins/cool.gif[/img]
For winter operation, I've fully opened the valve. Everything seems to be working well.
HTH,
crewzer
crewzer -- Y2K F250 SD 4X2 CC SB XLT 5.4LV8 AT 4.10LS
crewzer is offline
Old 12-18-2002, 01:58 PM   #13 (permalink)
I'll second what crewzer said. I left the valve slightly opened so the antifreeze in the core wouldn't become stagnant. With the mod I never needed to turn the AC any higher than 'Normal'.
Old 12-20-2002, 08:20 AM   #14 (permalink)
DirtFarmer's Avatar
A dumb question - how does the temperature adjustment work in our trucks when we're running the AC? If the heater core is always hot, what does the temp knob regulate?
2001 Cab and Chassis F350 SuperCab DRW 4x4. 7.3L. 6spd & manual xfer. snow plow pkg.
Home built flatbed featured on thedieselstop.com
DirtFarmer is offline
Old 12-20-2002, 09:48 AM   #15 (permalink)
jstrauss's Avatar
The temp knob controls a door that blends air coming direct from outside (or inside on Max AC) with the same air that has gone thru the heater core. When turned all the way cold, no air goes thru the heater core. But the core is so hot, it radiates heat into the box next door where the cool air goes thru and heats it somewhat.
1991 F150 SC 4.9L ZF5
1991 SAE Bronco 5.0L E4OD
1993 F250 4x4 7.3L IDI NA E4OD
jstrauss is offline
