I have a buddy that has a 2000 F-250 V10 auto that had the ABS light come on. Also the cruise control does not work, speedo meter, and the O/D light on the shifter is flashing. I did a search and found that the VSS (vehicle speed sensor) could possibly be the problem. Anyone have any ideas if this is the problem?
2003 F-250 Crew cab 4x4, 7.3, DI chip, Autometer gauges, K&N, 33x12.50x16.5 BFG's on custom wheels
Have friend with same issue, same symptoms. Replace of VSS took 15 minutes at most. Part was not available in aftermarket parts store, but was available at dealer & price was minimal..... VSS was located on rear differential if I remember correctly.
2K F350 SD PSD CC 4x4 LWB Lariat, auto, 3.73LS, Lone Star Liner, Bilstein, ProComp, BFG KO, Banks Powerpack, K&N, Di-pricol, Reese Titan Class 5, Sunnybrook 31'BKFS on Reese 16K, Jordan
I know it should of went in the gasser section but there is no one viewing that section and I need some advise quick. I figured this type problem had nothing to do with the engine more with the trucks sensors which are probably common no matter which engine it has.
2008 F-550 Regency Conversion Hauler 6.4 PSD
2006 Ford F-250 XL V-10 6-Speed
2006 Ford F-150 Crew Cab XLT
2005 Lincoln LS Sport
2003 Expedition Eddie B 4x4
2005 Jayco 31' Class C on a E-450 v-10 chassis
1997 Travel Supreme 40' triple slide 5th wheel
100 +or- head of Texas Longhorn Cattle...Longhorn is the healtiest beef around.....check it out.
NEED BEEF give it a try?
Had the same problem with my early '99 350 with 7.3. Replaced the VSS and everything was fine. I also had a defective ABS sensor in the front driver side wheel once that caused the cruise to not operate. Replaced that and the cruise started working again. But since you speedo is affected, it would most likely be the VSS.
