Re: Help..V-10 won't start......
Obvious like the IAC? Does it want to start but won't run? Will it run with your foot on the gas? Or nothing, just truns over but no fire? Did you check the fuel pump cut off switch under the passenger side kick panel? Just guessing... good luck!
2005 V10, AT, Fx4 Dark Stone Metalic, Crewcab F350, 4.10LS, shortbed, towcomand, Extang tonno **SOLD**
2007 Dodge 3500 Quadcab, 4x2, 6.7L Cummins, a/t, longbed, 4x2
Silence is golden. Duct tape is silver.
