I just had Jiffy lube service my truck but brought my own oil(Mobil 1 6 quarts as stated in the owners manual). They told me the V10 took 7 quarts and that I would be a quart low. Is this true? Is the owners manual wrong stating 6 quarts? I went ahead and had them change the oil and went and bought one more quart. Anyone have an answer????
99.5 F250 SC LWB Tuff Country Leveling kit,35x12.50 BFG's on Centerlines and more to come
2002 Silver F350/4WD/PSD/CC/LWB/SRW
4" Turbo back ATS Exhaust/DI Flip Chip
140k and counting
6 and only 6. Don't let those jerkies touch your truck! It is too easy to change oil in these trucks--do it yourself.
'00 F250 Reg.cab, 5.4, Superchip, 4R100, 4.10LS, ORP, 315/75R16 Big O XT, Kenwood CD, white grill, K&N, Removed swaybar, Astro 1800 Topper with off road roof rack with tire mount & KC's, hi lift jack, front levelled, Kennesaw winch bumper, Ramsey 9000# winch, custom 2x6 rear bumper, Exhaust exiting in front of rear wheel.
2004 F-250 CC SWB, sold due to POS 6.0
Old Trucks: 2002 Crew Cab shorty XLT 4x4 V-10, and Y2K F-250 Reg Cab 4x4 5.4 XL.
My Y2K 5.4 uses exactly 6.5 qts at each oil/filter change. I attribute the extra .5 qt. to the oil filter relocation. The oil filter is horizontal on normal 5.4's and vertical on mine. I see that some sources are referring to this hybrid 5.4L in the Superdutys as the "5.4l SD". It has the air filter and radiator overflow setup the same as the V-10 along with the "oil cooler" hoses coming off the radiator through the oil filter flange.
It wouldn't surprise me to see that you need 7 qts but I agree that it is simple to do your own changes on this truck. I installed a ball valve instead of the oil drain plug and, with the camper pack, the truck sits so high you can fit a BUCKET under the oil pan without even lifting the truck! Filter is much easier to get at than the 5.4 on my Dad's '99 Expedition.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR> The oil filter is horizontal on normal 5.4's and vertical on mine. I see that some sources are referring to this hybrid 5.4L in the Superdutys as the "5.4l SD". It has the air filter and radiator overflow setup the same as the V-10 along with the "oil cooler" hoses coming off the radiator through the oil filter flange.
[/b]<HR></BLOCKQUOTE>
Hmmm? Interesting comment. I know my F250SD 5.4L has a vertical oil filter and the cooler hoses but I had never crawled under a F150 5.4L to see if they are different. You are probably right and they are different. Learn something new every day. Mine takes 6 quarts to show in the middle of the Min-Max marks where you are instructed to put it.
2001 F-350 SuperCrewzer, Crew Cab Dualy LB XLT, 7.3L PSD, 4.10 LS, Oxford White w/ Silver lower tone, Med Grey interior, Power 40/20/40, Auto w/ Dacco Super Hauler TC and Magnafine, Towing Pkg w/ Dual Alts, Ford AIC, Prodigy, Gentex Mirror, Cobra 29WXNWST, 5ft Firestik II, X Monitor, Baldwin Coolant Filter, Sony OH Video system, Yakima Racks and basket, 45 gal auxiliary tank and 12V Pump, Towing a 26 Foot Prowler Lite.
Hmmm... the oil filter on my 97 F150 (new style) w/ the 235 HP 5.4 was vertical.
It also had the Class III trailering pgk which included a remote oil cooler. However, it seemed that without the remote oil cooler adapter, the filter would still have mounted vertically.
crewzer -- Y2K F250 SD 4X2 CC SB XLT 5.4LV8 AT 4.10LS TTPkg Black/Silver
6 quarts. Those marks on the dipstick are min and max oil levels. 6 quarts will bring oil level about 1/2 way between both lines.
'00 F-250 CC Shorty Lariat 4x4, V10, Auto, 3.73 L. Slip, 40/20/40 Bench, Off-Road/Camper Pkg/Class IV Hitch, Manual Hubs, Roof Clearance Lights, Pwr Trailer Tow Mirrors,Two Tone Dark Toreador Red/Black Trim, Med. Parchment Int.
Hail to the Redskins!
Thanks guys,
I added about 1/4 of a quart which put it just above middle of the marks on the dipstick. I didn't realize my truck had two dipsticks..... One for the oil and the one working at Jiffy Lube!
All is good.
140k and counting
I have used 6 qts. each change which brings the oil almost exactly to the middle of the "thatched" area on the dipstick. I am not burning any noticeable oil between changes so I do not fill any higher.
Hello. I went thru this with my truck when it was new. The dealer serviced it and used 7 qts. oil. Upon further investigation, with Ford Motor Co. the final answer was 6 qts. as the owner manual says. "NO MORE", It will fill to about middle of dipstick.
