Injector replacement
I've got what I believe is a stuck open injector. Pressure in the rail drops to zero quickly when you stop the engine. One plug is fuel fouled about every 6000 miles. Unplugging that cylinder's injector does not cause a miss when a clean plug is installed. All other cylinders produce a miss when injector is unplugged.
What other test should I perform?
If I replace that injector how do you inspect, clean, test the rest?
Claude-King@att.net
99.5PSD F350 3/99 CC XLT Auto 4X4OffRoad NO-ESOF 4WABS PTO/AIC Sterling BrushGuard W/front RecTube, Reading Low Profile Utilbody, 3.73LS SRW LWB Trailer & Camper, Oilguard bypass,Permacool 6pass Fan Aux trans cooler&filter, crankcase vent,Hutch Tank mods,8120#GVW empty
