I have noticed that a lot of you still run this filter. After reading some of the older post I was wondering if any of you have had trouble with oil getting on that sensor wire the other post were concerned about.
02 f-250, lariet, sc, sb, v-10, auto, 373, 40-20-40, cab lights, chrome step, manual hubs, Bilstien shocks, rancho stablizer, Lund vented visor, K&N air filter, Black over az. beige.
I've used a K&N filter for 4 years on my wife's Expedition. Not once have I had any problems. Just be sure to not over-oil the filter when you clean it and everything will be fine.
When it comes time to change the one in my SD, I'll go with a K&N.
I had the K&N filter charger kit on my other truck and had know problem with that, But friend of mine had problem with mustang. All he did was to take a Qtip and Rubbing Alchol rub this on the wire(mass air flow sensor) very carfully, this should take care of it.
2001 White F-250 PSD CREWCAB 4X4 SWB, DIABLO 78,315-75R16 BFGOODRICH A/T KO, Add A Leaf Front And Rear,X springs, Dyno Max Cat Back Exhuast, Isspro digital pyro, Isspro temp and boost gage
Well here is my opinion on the k&n, first they are good if you aren't in a dusty area, around here the dust is pretty bad at times, and they don't stop all the dust from getting in to the engine, and second I don't think they really make that big a differnce, not enough anyway to risk hurting your engine. Just my humble opinion, Mason
Had a K&N on my 1988 f-250 w/351 it went over 327,000 miles.No problems.Lived in up state NY to southern FLA.
Now Have one in this Truck and see No problems,just shake it out and clean every 20 or so thousand miles, [img]images/icons/smile.gif[/img] Iam happy with K&N..
1999.5 F-250 Lariat SD CC SRW LB Loaded V10 auto 4x2 K&N FIPK,Poweraid spacer,muffler deleted,custom seat covers,wood dash kit,tinted windows.BFGs 285s. A-Pillar gauges Tranny temp,oil pres and water temp.Hypertech PP 111 with themostat 160 deg.
ARE Custom Top W/ladder rack,Added a center seat/armrest,Clear corner lenses,TT mirrors, Rancho RS 9000X with incab remote, A work truck you can valet. NRA Life member. My Truck
