K & N Gen. II Filter and Intake/Borla Cat-Back - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 12-07-2000, 01:03 PM   #1 (permalink)
W-N
Has anyone installed the K&N Generation II Filter and Intake system on their V-10? If so, what results in power/mileage have you noticed? Do you have a cat-back exhaust as well?
Anyone have experience with the Borla cat-back system on a V-10 Excursion? Did you notice a change in power/mileage? How about noise level in the vehicle?
I drive at higher altitudes, 4,500ft+, and am considering the K&N Generation II with a Borla cat-back exhaust on my Excursion.
W-N is offline
Old 12-07-2000, 07:19 PM   #2 (permalink)
Re: K & N Gen. II Filter and Intake/Borla Cat-Back
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by W-N:
<HR></BLOCKQUOTE>
I have the K&N gen II kit and a Magnaflow cat back dual exhaust. I don't know if the high altitude would make a difference but here in corn country the mods I made did not even make a noticable power increase, but it looks & sounds cool.
1999 F250 4x4 Supercab, V10, Lariat, 4.30ls 6" National Spring Lift, Dual Shocks, 16.5 x 9.75 Weld Typhoons, 36x14.50 TSL Radials, K&N Gen. II, Magnaflow Dual Exhaust, Billet Grill, Line-X
1999 F250 4x4 Supercab, V10, Lariat, 4.30ls 6 National Spring Lift, Dual Shocks, 16.5 x 9.75 Weld Typhoons, 36x14.50 TSL Radials, K&N Gen. II, Magnaflow Dual Exhaust, Billet Grill, Line-X
My Truck
SDV10 is offline
Old 12-07-2000, 11:57 PM   #3 (permalink)
wldwilliam's Avatar
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>I have the K&N gen II kit and a Magnaflow cat back dual exhaust...the mods I made did not even make a noticable power increase<HR></BLOCKQUOTE>
Man, that is depressing
Bill McCall '01 F250 XLT 4x4 Crew Cab Short Box V10 Auto 4.30ls SRW
Manual T-case & Hubs*Off Road Pkg*Privacy Glass*Sliding Rear Window*Remote Keyless Entry*Power Driver's Seat*Power TT Mirrors*Captain's Chairs*Trailer Hitch
Soon to be: Fabtech 5.5" Lift*35" BFG Mud Terrains*Weld Wheels
2005 F350 | Lariat | CrewCab | 4x4 | 6.0 | 5 spd auto
Edge Insight & ScanGauge II monitors | Autometer FP gauge | DieselSite Coolant Filter | DR 2.5" level
18x10 Weld Evo Cheyenne 8 | 325/60r18 ProComp XAT | Upfitter Switches added | Extang Trifecta Tonno
Amp Research PwrStp | high idle mod | Ford F/P reg mod | latest EGR valve
03/06, 9K miles
oil leaks (r&r rear main seal and cam sensor), recall 05E16 (ECM recalibration), recall 05B32 (de-gas bottle fill level label applied & coolant level adjusted)
06/07, 22.5K miles
no 4x4 (r&r left side vacuum hose), e-brake malfunction (r&r parking brake ratchet assembly)
01/10, 30K miles
oil leaks (r&r bed plate, rear main, rear cover gaskets & o rings), CEL (r&r reman turbo, drain tube, update processors)
03/10, 30.5K miles
EOT +15°>ECT (r&r oil cooler, egr cooler, degas bottle & cap)
[all under warranty]
wldwilliam is offline
Old 12-08-2000, 04:19 AM   #4 (permalink)
The air filter prolly adds about 5hp and the cat-back maybe 10-15. Our trucks are so heavy I doubt you'll notice the difference. I added a K&N and a Borla single 3" and didn't notice any real gains either.
2005 V10, AT, Fx4 Dark Stone Metalic, Crewcab F350, 4.10LS, shortbed, towcomand, Extang tonno **SOLD**
2007 Dodge 3500 Quadcab, 4x2, 6.7L Cummins, a/t, longbed, 4x2
Silence is golden. Duct tape is silver.
V10 man is offline
Old 12-08-2000, 10:41 AM   #5 (permalink)
Banks Stinger kit includes both a high flow K/N type filter/housing, and their 3 1/2" Monster exhaust with Dynaflow muffler (catback). They also optionally provide a chip they call Ottomind. They quote improvements, with Ottomind like -1.00 second 0-60 mph, +0.37 mpg towing, -.67 second 40-60 mph. Best gains 18.1% HP and 18.1% torque, both @ 4400 rpm. All on regular gasoline!
I'm considering the Powerpack which includes their headers that they call Torque Tubes, Ottomind, and Transcommand, which firms up the transmission, for towing.
They have a sale going this time of year. www.bankspower.com
[This message has been edited by 3992824 (edited 12-08-2000).]
2000 Ford Excursion XLT 2WD, Chestnut/Parchment, V10, 3.73ls, autolamps/DRL's, Rear air deflector, Banks Powerpack with Transcommand, Edelbrock I.A.S's, 1 steel rear lift blocks, Tekonsha Sentinal. Towing a '00 Holiday Rambler 31 SKS, 10K gvwr
3992824 is offline
Old 12-09-2000, 12:27 AM   #6 (permalink)
W-N
Thank you for the information. I looked at their site and they did not list any applications for the Excursion. Although the intake should be the same, the cat-back is probably different for the Excursion. I sent in a question about this and am waiting for their response.
It's unfortunate that SDV10 did not see any gains. I wonder if Banks' system makes a real difference, matching their claims.
W-N is offline
Old 12-09-2000, 02:38 PM   #7 (permalink)
W-N, Banks does offer an application for the Excursion. Contact Joey Greenwood, jgreenwood@bankspower.com, with your questions. He can send you the info you want. Mention you saw a recommendation on the ford-diesel site.
3992824 is offline
Old 12-10-2000, 01:16 PM   #8 (permalink)
If you check both the manufacturers and various magazine's charts, you find that there is the 10-20 hp increase they advertise. Problem is that it manifests at around 5000+ RPM. In my 5.4 that's screaming (which I seldom do).
However, comma, you do get a better sound from the Borla catback and, presumably, the loss of the "exhaust flutter" that makes these Superduty gassers sound like diesels. Also better air cleaning if you believe what K/N says. The big thing is that you're on your way to getting the real power increase you're looking for. The Gen II plus the catback PLUS headers, a larger MAF orifice, a larger throttle body, and, maybe (haven't tried this) the spacer everyone seems so hot for that lengthens the t=body flow-through will show a noticable difference. Particularly in the mid range and down low where most of us want it.
I still maintain that if you're looking for more hp/torque in the rpm range most of us deal with (even on the freeway), getting your diffs boosted up to 4.56 is the quickest, cheapest way to make the truck a tire-burner and still run about 3K rpm at 70mph.
Regards,
Bob
Mulepick@aol.com
2000 F-250SD SC SWB 4x4 off-road 5.4L 4.10LS camper pack, 3 pod a-pillar gauges (water/trans temp, oil pressure), BedRug, SNUG-LID
Bob
Mulepick@aol.com
2004 Toyota $ Runner Sport 4x4 V-8
1993 Accord Wagon w/VTEC DOHC engine
1987 Rokon Trailbreaker
1999 BMW R1100RT
Mulepick is offline
Old 12-10-2000, 09:00 PM   #9 (permalink)
Hello everyone. I installed the Banks stinger system on my V10."K & N filter, with cat back monster exhaust. I have not noticed a great change in mileage or power. Maybe pulls my 5er just a pinch better. However, that 3 1/2 exhaust and 4 inch chrome tip look mighty impressive sticking out the side. Muffler is just a little to quiet, but sounds good when you put a good load on it up a hill. Banks is nice system, but pricey. Good luck with whatever you do.
99 F250 SC long box, 2WD, V10, Auto, 4.30LS, White, Lariat, Trailer Tow, Camper pkg, Banks stinger
2001 F350, Lariat, CC, LB, PSD, Dually, 4X4, 6 speed, 4.10 LS, all manual, oxford white, graphite interior, captain chairs, trailer tow, camper pkg, trailer tow mirrors. ISSPRO pyro and boost ev gauges, 4 inch DynoMax cat back exhaust. Straight pipe at moment. Jordan 2020 Ultima, Pullrite 18500 super 5th hitch. Dee Zee fifth wheel boxes (front and rear).
2000 Excel 33ft, double slide, 5th wheel,
__________________________________
Member since May 2000 from Iowa
V10T is offline
Old 12-15-2000, 11:48 PM   #10 (permalink)
W-N
Well, it just passed a week since I sent an e-mail to Banks about products for my X and still no reply. If they won't respond to a potential customer before the sale, I'd hate to see how they are after it. Does their customer service department really exist?
BTW - Thank you everyone for your replies so far. I appreciate the input.
W-N is offline
Old 12-17-2000, 10:04 AM   #11 (permalink)
W-N, Did you send the e-mail on the web site? I sent one too on the site, and didn't receive a response. I think that the web site is fairly new and needs more work.
If you contact Joey Greenwood at jgreenwood@bankspower.com, I'm sure you will receive a reply to your questions!
3992824 is offline
Old 12-18-2000, 12:15 AM   #12 (permalink)
Give them a little time. It took over a week for me to get their v-10 pkg in the mail. That was a few weeks ago. Problem with this time of year is, of course, Christmas. Also, don't know about Banks specifically, but many places have worker shortages due to a lot of people trying to use up their vacation time before they lose it at EOY.
When the weather warms up and money permits (anyone want to buy a boat ) I'm shooting for the full powerpack.
NoMo's website
NoMo is offline
Old 12-20-2000, 11:05 PM   #13 (permalink)
W-N
Since I have not heard from Banks, I took 3992824's advice and sent an e-mail to Joey today. I'll let you know what his response is.
Thank you everyone for your comments.
Happy Holidays!!!
W-N is offline
