Hello, I'm a new user. I've tried the search feature, but haven't had any luck in trying to find what the is the max tire size with stock alloy wheels and no lift kit. The truck is a 2000 F250 crew cab 4X4 V10.
You need to check your front spring code. You can run 285, 295, or 305/75/16 tires. Most report little tire rub or mounting problems. I would suggest the 285s without any form of a lift.
I ran 33x12.5x16.5 with minimal rubbing. I added a shackle lift and I have no problems now.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some "deleted" stuff.....
