misfire on V10... - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 04-12-2007, 10:55 AM   #1 (permalink)
misfire on V10...
Tech says intermittent ground from ECM preventing the injector from fueling the cylinders (3 and 5) causing the skip. Only recent repair had a blown plug repaired and needed a new coil pack. That cylinder is firing fine.The Tech says I need a new/used ECM.
Does anyone have a similar experience and what did you do about it?
thanks.
have a 2002 F350 SRW short bed sprcab
now have a 2005 F450 6.0 dump
had a 2002 3500 Duramax Dump (didn't want it)
had a 94 F350
had a 2001 F350 SC SRW V10 (cruise control FIRE!)
had a 2003 F350 7.3 XLT
Had a 1999 F250 7.3
had a 1995 PS F350 Dump
joestruck is offline
Old 04-12-2007, 11:17 AM   #2 (permalink)
Re: misfire on V10...
The misfire I experienced was due to a bad COP. Initially it did not throw a code (for about 1.5 months), but finally the COP died completely & thew a code indicating the misfire on cyl 4. I replaced the COP & everything is good.
If there is an intermittent ground, then make sure it's properly grounded...don't just replace the PCM.
jade97 is offline
Old 04-12-2007, 06:26 PM   #3 (permalink)
Thank you for your reply.
What is a COP? I think I know,but want to be sure I understand you.
Also, I really don't know enough about it but doesn't the PCM provide the ground internally (assuming wires to and from are ok), and in turn this "cycling" fires the injectors ?
It was tested with a "node" ? I think that the device has an LED that blinks when the cylinder is to normally fire the injector. I was told #3 and #4 fire intermittently based on the test.
In turn they are telling me it needs a new 'puter.
We are in no rush , I have another vehicle and we haven't found a used one yet.
Any more thoughts? [img]/ubbthreads/images/graemlins/confused.gif[/img]
Thanks.
had a 94 F350
Had a 1999 F250 7.3
Old 04-13-2007, 08:35 AM   #4 (permalink)
COP=Coil On Plug, or as you called it a coil pack.
In my case I used a OBDII code reader that I picked up from EBay for $28. Your local Autozone will read the codes for free. When my misfire was intermittent, no code was stored in the PCM. When the COP finally died, the Check Engine light did not come on, but a code was stored in the PCM and read by my code reader.
Not sure if this helps?
Finding a bad ground in electronics can be difficult (I'm an Electrical Engineer...whoopdie-doo [img]/ubbthreads/images/graemlins/phoney.gif[/img]). By the description you gave of their troubleshooting, well I have my own opinion.....I doubt it is "a bad ground in the PCM".
jade97 is offline
Old 04-15-2007, 06:32 PM   #5 (permalink)
Someone probably knows for sure, but I believe I was told the ECM grounds internally , and this cannot be repaired,only replaced with a unit that is compatible with the VIN. Assuming all prior diagnostics were correct to this point.
I really don't know enough about it, that's why someone else is fixing it for me naturally. I spent $450 on the plug repair, and then another $250 on 2 more COP's and more diagnostics to find the skip, so I am trying to find out as much as I can .
I'm at the point where I want the "final" repair done .
Thanks again for the info..
had a 94 F350
Had a 1999 F250 7.3
Old 04-17-2007, 08:43 AM   #6 (permalink)
I hope it works out for you.
In my opinion, I think that they do not know what the problem is, so they just want to start throwing new parts on your truck until the issues is solved.
jade97 is offline
Old 04-17-2007, 11:01 PM   #7 (permalink)
Yes, I was skeptical myself, and it's pretty much the reason I originally posted.
Not to belabor this problem, but I have checked with my FORD service advisor, the one who I have used for the past 15 years (when I had new trucks under warranty!), and he agrees with the method used to diagnose the problem. He verified the ECM provides the ground, and that it can't be simply re-flashed and he gave me some more background so that I am comfortable with the other guys diag..
It still SUCKS though!
Thanks.
had a 94 F350
Had a 1999 F250 7.3
Old 04-25-2007, 04:00 PM   #8 (permalink)
Please let us know the outcome.
jade97 is offline
Old 04-28-2007, 10:41 PM   #9 (permalink)
What does a misfire sound like? I've got a wierd sound/vibration on my 2005 V-10. Almost sounds like a heat shield or other metal component underneath is vibrating. Very intermittent, and only when the truck is rolling (i.e. it is under some degree of load). No codes, and the monkeys at the stealership are content to keep replacing exhaust components. Wondering if this is what I'm seeing.
There is no room in this country for hyphenated Americanism. For an American citizen to vote as a German-American, an Irish-American, or an English-American, is to be a traitor to American institutions; and those hyphenated Americans who terrorize American politicians by threats of the foreign vote are engaged in treason to the American Republic. -- Theodore Roosevelt, 1915
dockrocker is offline
Old 04-28-2007, 11:08 PM   #10 (permalink)
I recall seeing a TSB that pertained to the issue you are having. IIRC, it directed us to replace the front exhaust pipe with a revised part. I no longer have OASIS access, so I can't look up TSB's to look up specifics, but there may be another tech here who can look it up, or may have a little better memory than what mine is tonight.
Buddy
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip.
My Truck
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
budman451 is offline
Old 04-30-2007, 11:39 PM   #11 (permalink)
Thanks - the dealer has replaced the muffler with no effect. It does sound like it's coming from about where the exhaust pipe would start - almost around the tranny hump. I'll get it in this week and see if they can (not) find the problem, again....
Old 05-01-2007, 11:32 AM   #12 (permalink)
On my 99, the sound you are describing was made by the heat shield at the base of the down pipe. One of the welds broke. I used a pipe clamp to put it back on and the sound went away.
Robb
Robb Wing from Cincinnati,Ohio
99.5 F250SD XLT,4X4,CC,SB,SRW,V10,Auto,3.73LS,ESOF,Deep Wedgewood Blue,Swiss Cab-high Cap,Pioneer DEH-P7300,Alpine Amps,Infinity Sub,Street Scene Grill Inserts,full-chrome grill,Fumoto,SPA Gauges,Rancho stabilizer,Heated/Lighted TT mirrors, Jordan Ultima 2020,TYC Elegante Tail Lights,Great Covers Endura Seat Covers,Auto Lock Underseat Drawer,Hella Micro DE Fogs,Full Chrome Front Bumper,PML Diff Cover, JAD Solutions LED running lights below doors,18" Harley Wheels,keypad,chrome tow hooks,leather steering wheel, PF 2-piece Rotors and "Z" pads in front - PS Cryo and Hawk LTS in rear,BANKS Stinger Plus,Banks TransCommand,GMT Transmission,Bilstein 5100s My Pics
todlake is offline
Old 05-01-2007, 11:46 PM   #13 (permalink)
That's what I believe it is as well, a heat shield. Unfortunately, my local dealer is more of the "replace and pray" school of diagnosis, so I have to help him along....
Old 06-05-2007, 01:23 PM   #14 (permalink)
joestruck,
Did you get your truck straightened out?
jade97 is offline
