I've been spelunking around this 5.4L "hybrid" engine in my Y2K F-250 for the best locations to install the sensors for oil temp, trans temp, and oil pressure gauges. I say "hybrid" because this thing has eight cylinders but looks more like a V-10 than the 5.4 they put in 150s and Expeditions. Removing and teeing off of the existing oil pressure sensor would be very hard as it is occluded by various frame parts. I noticed a plug underneath the rearmost freeze plug on the driver's side that looks like it takes a 10mm hex wrench to remove. This would be perfect unless there is something behind it. Anyone know? Where did everyone else put, or have put, this sensor (and the others as well)?
I've got the Chilton, Ford, and Haynes manual most closely related to this engine and none is very specific. This is common for Chilton but an unpleasant surprise from Ford. I wish Haynes would put out a SD manual but they say there just isn't the demand.
Informed advice invited.
Bob
Mulepick@aol.com
2000 F-250SD SC SWB 4x4 5.4L 4.10LS camper pack
