Re: O2 sensors
Dummy o2 sensors are designed for OBDII vehicles that have had the catalytic converter removed and are setting a downstream o2 sensor code, because the downstream sensor is following the upstream sensor. Normally the upstream sensor switches voltage between 0 and 1 volt. The downstream sensor should stay steady, but when the cat is removed it also starts switching, causing a CEL.
The dummy sensor send a constant voltage siganl back to the ecm to trick it into not setting a code. I know you can get these from summit racing and jegs.
Late 99 F250 Crew Cab SB, dp tuner stock, hi idle, 80, 120, ford ais, magnaflow ss exhaust leveling kit rear add a leafs and pro comp xtreme all terrain
