oil / coolant for v-10 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 03-01-2009, 01:03 PM   #1 (permalink)
Cratos's Avatar
My Photos: (15)
hi gang i have to change the coolant and oil on the GF 2001 v-10 of cource she got it used and did not get all the books,
so I need to know how much oil and coolant to get for her. I plain on flushing the coolant system and puling a block plug to get it all out.
thanks for your help.
97 F-250HD Super Cab 4X4 E4OD, 3.55 gears, swamps 238'/80s & SWAMPS Chip,Beans D-66 Turbo, Adrenaline HPOP & Reservoir Filter, BTS,TSM Disk Rear Brakes,DIY Electric Fuel system,DIY Air Filter,Auto Meter Dash Mounted Gauges: Trans Temp, Boost, EGT, Oil Temp, Oil Pressure.Water Temp,Fuel Pressure Gauges,3 Inch Intake plenums, 4 inch MBRP, Intercooled, CCV mod.
294,000 Miles and still going Strong.
Cratos is offline
Old 03-01-2009, 08:19 PM   #2 (permalink)
Charlie98's Avatar
The V-10 takes 8qts with a filter (Fram PH2, etc) Can't help you on the antifreeze...
Charlie98 is offline
Old 03-01-2009, 10:08 PM   #3 (permalink)
Homegrown's Avatar
Per the service manual - SIX (6) quarts of 5W-20 with a filter (do yourself a favor and get a Motorcraft FL-820S at Wal-Mart).
The cooling system holds 28.5 qts, or 7 1/8 gallons. I normally drain the system, flush it with 4 gallons of distilled water, drain it again, add 4 gallons of coolant, and add 3-4 gallons of distilled water until the level is between min and max on the de-gas tank.
FOKISD Charter Member from Hillsboro, OHIO
'01 F-350, XL, SC, LWB, V-10, 4R100, 3.73 LS, High Back Buckets, TT Mirrors, Roof Lights, Camper Package - Check my Photo Gallery for modifications. Michelin LTX M/S on Mickey Thompson Classic II's, A.R.E. DCU cap, Reese Titan V and Draw-Tite front reciever, Audiovox cruise control, Wolf center console, Truck-Lite rear ID bar, Hella FF75 driving lights. Bilsteins on each corner.
Homegrown is offline
Old 03-02-2009, 10:00 AM   #4 (permalink)
Cratos's Avatar
My Photos: (15)
got the motor craft filrt and used 7 qts qnd she was full
will get to the cooant whan it warms up
Cratos is offline
Old 03-06-2009, 09:26 AM   #5 (permalink)
Charlie98's Avatar
Someone must have moved my 'Full' mark on the dipstick...
Old 03-07-2009, 12:50 PM   #6 (permalink)
akrewat's Avatar
One thing, in the owner's manual and elsewhere, Ford says to put in six quarts, and then check the oil. If it's between the FULL and ADD marks, DO NOT add any more oil.
There's this quirk that the V10 has, when you start it up, and move it a few feet, and shut down, say about 1 minute running total, and then restart the next day, you may get a big POOF of blue smoke. Mine did that regularly. But I was also adding oil all the way to the FULL mark on the dipstick. When I went back to only 6 quarts total, it hasn't done it since.
For the record:
2-valve V10 takes 6 quarts.
3-valve V10 takes 7 quarts.
'01 F250SD V10 auto 4x4 SC SB Volant CAI, ebay headers/y-pipe
'74 F250HD FE390 4-speed 4x4 LB - heavily modified 390 (deceased)
akrewat is offline
