Oil & filter for a 5.4L - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 12-29-2000, 08:37 PM   #1 (permalink)
Does anyone have a recommendation for a good motor oil for the gas engines? What about oil filters? Does anyone use the Magnefine filter advertised on this site?
2001 F-250 XLT SD CC 5.4L 3.73 & Auto tranny. A white monster!
fwlaura is offline
Old 12-29-2000, 09:21 PM   #2 (permalink)
Re: Oil & filter for a 5.4L
Unfortunately, this is kind of a "what's your favorite color" issue. Everyone has a favorite oil- be it synthetic or petroleum based. Use whatever you want and change it regularly.
Personally, I run Mobil 1 synthetic oil and use the Ford filter. Still do changes every 3k miles. It may be wasteful, but it's my truck and my money.
I've not used the Magnefine products, but their "strong" magnet works only within a 5mm range!?! I stuck a magnet from an old hard-disk on my tranny pan and one on the engine oil filter. I'll guarantee that my "disk" magnets will draw particles from more than 5mm away.
2000 4x4 F250 XLT SuperCab SWB- V10, Automatic, 4.30LS, Offroad Pkg, Camper Pkg, OEM Hitch, Tape/CD Player, Remote Keyless Entry, Sliding Rear Window, Privacy Tint, Aluminum rims, 265/75R16 OWL tires, Line-X bedliner
NoMo's site
NoMo's website
NoMo is offline
Old 12-30-2000, 10:01 AM   #3 (permalink)
I agree use what you like just make sure the filter has the anti drain back valve or whatever it is called to hold oil in the filter when engine is not running i use a purolator on my expy with the 5.4 and have not heard any piston slap yet (60,000) but i think i will go to ford and buy the motorcraft filters just to be sure from now on also use valvoline oil
2001 F250 V10 SC SB
Island Blue Beauty Line-X B+W hitch Huskey liners
furbis is offline
Old 12-31-2000, 11:49 AM   #4 (permalink)
I also use Mobil 1 5W-30 and the Motorcraft filter in/on my 5.4L.
I installed a Magnefine filter in the return line from the oil-to-air cooler; I think it contains both a paper filter element as well as the magnet.
It's supposed to last for 30K miles, so it should be good for a few more weeks . In an admittedly warped kind of way, I'm looking forward to cracking it open when I do change it .
crewzer -- Y2K F250 SD 4X2 CC SB XLT 5.4LV8 AT 4.10LS 4W-ABS TTPkg etc. Black/Silver plus 285/75R16D tires, trans cooling fan, TT gauge & Magnefine filter.
crewzer is offline
Old 12-31-2000, 04:30 PM   #5 (permalink)
My Photos: (19)
If you use the Ford Motorcraft filter see if your local walmart or autoparts store stocks them. Should be cheaper then ffrom a ford dealer for the same filter. I have gotten a motorcraft filter for my truck at AutoZone for $2.99. It is $5.xx at the Ford Dealer. Just a suggestion.
Stephen
1994 F-250 XL 351 (no
diesel yet) 5 speed 4.10
2005 F-250 XL Reg. Cab 4x4 5.4/ZF6/3.73
1994 F-250 XL Reg. Cab 4x4 351/ZF5/4.10
2003 Kubota L3130DT
My Pics
sbrem is offline
Old 12-31-2000, 07:17 PM   #6 (permalink)
I read some oil filter tests on all major brands 2 months ago (should have saved the link) and they liked the Purolator and one other (can't remember the other). I just changed my oil @ 1500 miles and put a Purolator in (V10). I was getting "valve train noise for 1-2 seconds at cold startup with the original factory filter, and since the Purolator went in, no problems with the noise whatsoever. It makes me think that the original had a faulty drain back valve. Just my 2 cents worth...
Y2k F350,V10,4x4,Lariat,SC,Auto,Tow pkg, Rancho 9000, Air Ride,Long bed,Lance Camper
Y2k F350, white with harvest gold trim,V10,4x4,Lariat,SC,Auto,Tow pkg,camper pkg,ESOF, so-called limited slip, off road,3.73,Rancho 9000 w/ in cab control, Ride Rite Air Bags,Long bed,Rickson 19.5" wheels, Michelin XDE-MS,Lance Camper, BugDeflector2, Stull Grill, KN., Flowmaster 50
outpost22 is offline
Old 12-31-2000, 07:34 PM   #7 (permalink)
Good point sbrem. I should have really stated that I use Motorcraft filters. Buy them and the oil at Wal-Mart. Be watchful of special "value-size" containers of oil. They are normally 5-quart jugs, but only cost as much as three 1-qt. bottles.
NoMo's website
NoMo is offline
