Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Gas Engines
Gas Engines Discussion of the gas engines available in the 1999-2007 Super Duty trucks
Old 12-25-2006, 10:28 AM   #1 (permalink)
Oil Filters Tightening In Service
Hey Guys
Looking for some opinions on this one. Removal of the factory oil filter on my new F150 was an exercise from hell. Dam thing would not come off. Broke my filter wrench and ended up using too small a set of channel locks to finally get the stupid thing out...
So I posted my frustrating experience on another site and got some comments about how spin on filters tighten as the miles increase. This was something I've not heard.
What do you all think?
Merry Christmas, hope all enjoyed a great day!
Henry
Henry
2007 Ford F-150 Lariat Supercab 5.4 4x4
svt2205 is offline
Old 12-25-2006, 11:15 AM   #2 (permalink)
olddieseldude's Avatar
My Photos: (15)
Re: Oil Filters Tightening In Service
...spin on filters tighten as the miles increase...
I'd have trouble believing that. I think we just put them on too tight. First, lube the seal well, then spin the filter on until you can't rattle the filter on it's threads, then just turn it 3/4 to 1 turn. That's all it needs or over time with heat cycles when the lube dries up that oring becomes a tough lock washer to overcome at the next oil change.
RickN
White '99+ F250 SD XLT 4x2 SRW, 7.3PSD, 6spd, SuperCab, Short Bed
(mods listed in comments under photo in above link)
olddieseldude is offline
Old 12-25-2006, 01:54 PM   #3 (permalink)
Oil filters DO tighten from heat cycles over time.I couldn't believe how hard it was to remove my oil filter last change and I did the one before and know better than to tighten it on too much.And I don't use an impact wrench on the drain plug either!
'02 Black F-350srw Lariat. 7.3/CC/SB/OR. TN .84 w/Hi-flow outlet,Non-EBP ped,BWD coated/bellowed up-pipes,D.P.F5(stock,Hi-idle,60tow,80econo,120race),4" SS Magnaflow,BDS stabilizers ,Fluidampr,AFE Stage2w/PG7&pre-filter,Spearco 6.0 IC,Sonnax,FT T/C,PML pan,6.0 cooler,HPOX,Airdog,ITP reg.return,MAP Maximizer,8 spring front, BFG 315/75/16 AT's,DTS 4.56LS gears,untrue Truspeed,Mag-Hytec cover,Dieselsite SS ESOF lines,coolant filter,203* stat w/billet&Fleetrite,Optix fuel on column,Ultra-Lite trans,pyro,boost on pillar.All fluids Mobil1,Energy polys,Centramatic,Fumoto,Billet,Line-X,Husky box,Extang,EGR,Alpine,Viper,Dynamat,Sirius,PIAA,Hu sky-Liner,Bilsteins. Door ding,overhead console,Snowman,Zoodad,Harpoon,AIH,Marinco,CCV,foi l mods.
ELLIOT02 is offline
Old 12-25-2006, 09:07 PM   #4 (permalink)
My Photos: (15)
I wonder if the construction of a filter, the way the internal metal parts are formed and relate to each other, would allow movement or deformation due to either heat or pressure causing the relationship between the sealing surface and the threaded feature to lengthen, effectively adding load to the gasket surface? I can't believe that it actually spins tighter.
Maybe you could try antisieze on the gasket next time and see if it stays lubed better at oil change time.
Old 12-25-2006, 09:40 PM   #5 (permalink)
They do not spin on tighter, the heat cycling is what causes it to come off harder.
And oil is all you should put on the o-ring, that is what is specified.
Dave
Smokyred- RED 11/97 F250HD XLT SCLB Auto 4.10LS 4x4 OFFROAD Powered By 2L Motorsports and SWAMPS.
Mods: AM Ultra-Lites, DiPricol HPOP gauge,TS/2L Moto Chip, 4" Straight-Piped, Poor boy's intake, Swamps II's, BTS, 285 BFG A/T's on factory Alcoas. Lots more to install, see below!
On the bench: AirFlo S400, Swamps 275's, Studs Rods and Springs for the top end, and some other stuff.
My Pictures
DD- SILVER 11/97 F350HD XLT RCLB Auto 3.55LS 4x4 OFFROAD
Mods: Redneck straight-pipe, TS/2L Moto chip.
smokyred is offline
Old 12-26-2006, 07:48 AM   #6 (permalink)
But what about heat cycling is doing this? I know that most any threaded component on aircraft is safety wired to prevent loosening. These parts are also heat cycled, bigger temperature delta too. What am i missing here?
And, thanks guys for what you've offered so far. Really appreciate it!
Henry
svt2205 is offline
Old 12-31-2006, 12:54 PM   #7 (permalink)
I changed my oil at 300 miles on the truck in my signature. I do this on every new engine I own. The filter was a bear to come off. I think a robot must spin them on with a dry gasket. Ever since every 3000 miles , the MC filters come off just fine. I do use a set of filter pliers for removal only. To put them on, I can get the 3/4 turn, after gasket contact, using my two hands but I pull wrenches for a living. A keyboard jocky might need a strap wrench.
2005 F350 Crew Cab FX4 Lariat SRW LB 3v V10
True Blue with Arizona Beige
Moonroof and all the other goodies.
Paid for A/T tires and got M/S
My dealer gave me a rebate on the tires.
Diesel Don is offline
