Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Gas Engines
Gas Engines Discussion of the gas engines available in the 1999-2007 Super Duty trucks
Old 06-25-2005, 10:06 PM   #1 (permalink)
Overdrive switch shoots fuses
When I disable the overdrive it shoots the fuse and I lose my instrument cluster. It's a 2000 excursion v-10. It also won't start back till I replace the 10 amp fuse that blew. Any ideas?
Thanks,
00 Excursion 6.8 4X4 4.30 LS
97 F-350 SRW R/C 4X4 7.3 Auto. 4.10 LS
91 F-250 R/C D-60 conv. 4X4 7.3IDI Manual 4.10 LS
87 Chevrolet 1/2 ton 4X4 5.7TBI Auto. Stepside
71 Land Rover Series IIA 2.25 Manual
DarylB is offline
Old 06-26-2005, 09:19 PM   #2 (permalink)
Re: Overdrive switch shoots fuses
your modle year is prone to have a chafing wire that shorts out in the shift stem for the OD button. Do some searching in the general forum for "Larrys little secrets" there are listed the steps to fix in here some place.
White 05 F350 King Ranch 3 valve V10 5R110 Auto 4.30:1LS 4x4 LWB SRW born on 3 Sept 04
fredvon4 is offline
Old 06-28-2005, 08:09 PM   #3 (permalink)
Damn I had the same problem in my '97 150.
I just never took it out of OD.
'04 250 CC SB V-10 Lariat Shadow Grey 4X4
jpeckinp is offline
Old 06-28-2005, 09:53 PM   #4 (permalink)
Thanks fredvon4, I found larrys little secrets you suggested, but couldn't find the tip. I'll keep tryin.
[img]/ubbthreads/images/graemlins/confused.gif[/img]
Daryl
DarylB is offline
Old 06-29-2005, 02:09 PM   #5 (permalink)
Try the general forum for "OD wire short"
Also was some discussion on FTE (www dot FordTrucks dot com) in the SuperDuty Heavy Duty forum.
I just remember reading about it back a few years ago.
You might drop Larry a PM and see if he can dig up the fix.
fredvon4 is offline
Old 06-29-2005, 09:06 PM   #6 (permalink)
fredvon4, a big THANKS to you. I took the column cover off and there it was, a bare OD wire. It looks like the casting that the shifter arm goes into rubs a little insulation off every time it goes into drive. A little filing on the cast piece and electrical tape on the wire and its fixed.
Thanks again,
Daryl [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
DarylB is offline
