Piston slap? (general)
Could someone please describe the symptoms of "piston slap" as described on other threads? Is this the same as a 1-2 second (or more) knock I hear on cold start-up, or something else?
Does it occur only at start-up or at other times? Is is caused by lack of lubrication high in the engine? (read a reference to someone solving their problem by changing to a filter that wouldn't allow oil drain-back...)
I've had this symptom for as long as I can remember in my '87 302, mostly in the winter time on cold start-ups, and always wondered what exactly it was -- either piston wear or lack of lube or both (and I've run with Amsoil for the last 95K!). I have found, though, that engine oil additives (Prolong, Duralube, etc) will take care of it in the short term (they only last 3-4000 miles or so). Unfortunately, use of those additives destroys the longevity of Amsoil, defeats my purpose for using it, and shortens its life significantly (as my periodic oil test results show). Nonetheless, if it really bothers you, an extra $20 bottle of something can make it go away during the cold weather months...
Thanks.
Soon to buy: 4x4 Quigley E350 - V10 or PSD???
2001 E350 PSD, Deep Emerald Green, 3.55 LS, Premium package, dual alts, rear A/C. Quigley 4x4, Transfer Flow rear tank (27+26), handicap mods, custom interior, Reunel tire carrier w/ Hi-Lift, Sportsmobile nerf bars (black), Amsoil lubes and Dual-Gard bypass oil filter, Amsoil air filters, Eclipse/JL Audio sound system w/ Sirius & 120GB Neo Car Jukebox (MP3 player), J&J stainless grill, Reunel Stainless bumper, 12000# Warn winch, PIAA lights, Bilstein shocks, Ultra Magnum wheels, Michelin tires (265/75-16), Correctrack rear wheel spacers, Bushwhacker flares (painted), Velvet-Ride spring shackles, p/s filter, external tranny and coolant filters, Wicked Wheel, Autometer gauges(5), 203 thermo, BRV+, removed air intake heater, Optima Yellow Tops, "Harpoon" mod, DP-Tuner, 4" exhaust w/ Aeroturbine, Airdog, HX-mod.
Next on the List: a blown tranny!
