Re: Power Steering Noise/Problem?
I have read more than once, that F*rd power steering is unusually loud when compared to other makes. I brought my wifes Mustang in for service because the PS was loud and they agreed. They replaced the pump. When I picked it up, it sounded just as loud to me. After I got it home, it does seem a little quieter but still loud and it's quite a bit louder than my Super Duty.
If I listen for it, I can hear my trucks PS pump but it's not overly obnoxious
Bill McCall '01 F250 XLT 4x4 Crew Cab Short Box V10 Auto 4.30ls SRW
2005 F350 | Lariat | CrewCab | 4x4 | 6.0 | 5 spd auto Edge Insight & ScanGauge II monitors | Autometer FP gauge | DieselSite Coolant Filter | DR 2.5" level 18x10 Weld Evo Cheyenne 8 | 325/60r18 ProComp XAT | Upfitter Switches added | Extang Trifecta Tonno Amp Research PwrStp | high idle mod | Ford F/P reg mod | latest EGR valve 03/06, 9K miles oil leaks (r&r rear main seal and cam sensor), recall 05E16 (ECM recalibration), recall 05B32 (de-gas bottle fill level label applied & coolant level adjusted) 06/07, 22.5K miles no 4x4 (r&r left side vacuum hose), e-brake malfunction (r&r parking brake ratchet assembly) 01/10, 30K miles oil leaks (r&r bed plate, rear main, rear cover gaskets & o rings), CEL (r&r reman turbo, drain tube, update processors) 03/10, 30.5K miles EOT +15°>ECT (r&r oil cooler, egr cooler, degas bottle & cap) [all under warranty]
