Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Gas Engines
Gas Engines Discussion of the gas engines available in the 1999-2007 Super Duty trucks
Old 12-13-2005, 02:26 AM   #1 (permalink)
PSDfreak's Avatar
Programming Keyless in '99 F-350 10V
I have a couple of spare remotes from my dads '02 F-250 V10. My girlfriends old man has a '99 F-350 V10. Two questions:
1) Will the remotes from the '02 V10 work for the '99 V10?
2) How are these remotes programmed for the truck?
My truck has a plug under the driver side kick panel that you jump and the locks cycle, then you hit a button on the remote and if they cycle you're done...is it similar to this?
Thanks guys,
Casey
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is online now
Old 12-30-2005, 04:32 PM   #2 (permalink)
Re: Programming Keyless in '99 F-350 10V
Turn the ignition switch from the 1st posisition (not off) to the 2nd position until your power locks jump up and down. Process will be about 7-8 turns. Press one button each remote you want programmed and you are done. Each remote that sucessfully gets programmed will make the locks jump up and down.
2002 F-350 2wd, 6sp, Crew Cab, Black, bone stock as of 12/11/2005.
nc_motorsports is offline
Old 01-01-2006, 11:47 AM   #3 (permalink)
PSDfreak's Avatar
great thanks very much. I have been waiting a while for someone to come back with an answer... I appreciate it!
Thanks,
Casey
