Im getting ready to order a new superduty and have been looking at this site and others and fuel mileage, power, and some other questions end up with the gear ratios getting brought up. But it seems most are talking about the auto tranny. I am wanting the 6 speed for what I do(working I tow heavy loads everyday). My question is with a V10 should I still get the 4.30s or would 3.73s be better since the 6 speed starts out so much lower with the O/D being very close on both the 4 speed and 6 speed. It will probably be stock for awhile, but ill eventually cave in and go up to 35" tires down the road. What are your suggestions? How does the fuel mileage compare with the manual vs auto tranny?
1999 Work Truck Superduty, reg cab 4x2 V10, no mods yet, YET...well stereo system on its way
If you are going to get 35 inch tires then get the 4.30's. If you get the 3.73's and put 10,000 lbs behind you you will never stay in overdrive with 35's.
I would speculate that you will get unloaded fuel mileage between 10 and 14 depending on driving style. You can expect a 10% increase if you get the hand shaker.
I have the 4.30s with an auto. I'd go that way again. Great for towing, plus I have 295 BFGs, so 3.73 wouldn't be the way to go. I just had a US Gear OD installed last week, so now the ratios are actually 3.44 and 4.30.
2000 F-250 Lariet 4X4 long bed crew cab V10 Automatic 4.30 - US Gear overdrive, K&N air filter, Banks TransCommander, BFG 295 75R16, sprayed bedliner, SnugTop fiberglass bed lid
Redone, Do tell more on this US gear OD. I've just looked at their web site and i'm very impressed. I bought my truck "just because", i dont pull, its a daily driver and used for road trips. Im looking to increase the fuel mileage and i'm thinking this unit will help. If you could fill us in on the details of the install and operation that would be great. Thanks.
__________________ 2002 F250 V-10 CC SB 4X4 AUTO 4.30LS OFF ROAD PACKAGE,DIXON BROTHERS RACING PREUNNER BAR,2007 GRILLE & HEADLAMPS,CHROME EMBLEM MOD, HOME MADE MESH CAB MARKER LIGHTS, HELLA AIR HORNS, PINCH WELD HOLE COVERS, WHITE EXCURSION DOOR HANDLES, LIGHT FORCE OFF_ROAD LIGHTING ,HOMEMADE AIR INTAKE,TRUESPEED,PACIFIC TRUCK EQUIPMENT UTILITY BODY
