Re: rear end tag
...Two things may help you decide. First, jack the rear in the air so both tires are off the ground. Put truck in neutral(be sure and put blocks in front!!) and spin the rear tires. If both tires spin the same way, you have a limited-slip axle. The second way...look inside the drivers door jamb for the axle codes. Most of the time Ford will use a Letter designation with the axle code to signify a vehicle has a "posi" rear end. Good luck....
Y2K 250 4x4 Island Blue XLT SB SC V-10 Auto 3:73LS every option except esof. goodies: BORLA exhaust, K/N filter, Jet performance chip, RHINO Liner, Husky Floor Liners
IN GARAGE: 2011 F350 4x4 C.C./L.B Dark Blue Pearl....Loaded
Traded 2009 F350 4x4 C.C./L.B.- 6.4 Auto
Traded in 2004 6.0 4x4 Crew Cab
Traded in 2000 V-10 4x4 Island Blue Supercab
