Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Gas Engines
Gas Engines Discussion of the gas engines available in the 1999-2007 Super Duty trucks
Old 07-22-2008, 08:30 PM   #1 (permalink)
Replacing Fuel Filter on F250 5.4L 2003
I was talking to my local stealer and he said to replace the fuel filter is about $110.
Two questions:
How important is it to change the fuel filter?
Does any know if depressurizing the fuel system is difficult?
Is it really that hard?
phurley is offline
Old 07-22-2008, 09:48 PM   #2 (permalink)
bockhold's Avatar
Send a message via AIM to bockhold
Ive done my diesel truck and our gas car. Its not hard but it may involve some cranking to rebuild the pressure in the fuel again.
Jarrod
NRA member
1997 F350 4door 2wd long bed white 7.3L Powerstroke, E4OD, C5 4:10LS diff 326K miles on org engine
and is being repaired
bockhold is offline
Old 07-22-2008, 10:00 PM   #3 (permalink)
chuckster57's Avatar
Two questions:
How important is it to change the filter: VERY important. I have seen some so clogged that the engine is starving for fuel, rough idle and finally the "check engine light". How hard to depressurize system. Easy, let the truck sit for about 1/2 hr. Then look for the "schrader" valve (looks like a bycicle tube valve) on the fuel rail. Just uncap it and put a rag on the engine...press the center and let it flow. Once the filter is replaced, the truck will most likely start right up and then "stumble" for a few seconds and pick right up. IIRR the filter is located in the frame rail on the drivers side. Make sure of the flow ( will be an arrow) and use the NEW clips to hold the lines on. Watch your eyes as there will still be fuel in the filter and it will run out.
1994 F-350 7.3 IDI Turbo, crew cab, E4OD, LB, Dually,
1997 Jayco fifth wheel 323 RKS, Robins 16K dual axis hitch
Apillar pod with: Autometer C2 Series gauges: pyro,trans, boost
Hypermax Cowl induction, Flex-A-Lite 26K tranny cooler w/fan
K&N air filter (we'll see in a million miles)
Tekonsha "prodigy" brake control
Train Horns: Pictures here
chuckster57 is online now
