reset computer best way ?? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 07-18-2001, 10:05 PM Thread Starter
twinbulls's Avatar
When I reset my computer should i disconnect the battery or is there a fuse I can pull just for the computer??to avoid loss of radio settings ??and how long ?? [img]images/icons/crazy.gif[/img]
1999.5 F-250 Lariat SD CC SRW LB Loaded V10 auto 4x2 K&N FIPK,Poweraid spacer,muffler deleted,custom seat covers,wood dash kit,tinted windows.BFGs 285s. A-Pillar gauges Tranny temp,oil pres and water temp.Hypertech PP 111 with themostat 160 deg.
ARE Custom Top W/ladder rack,Added a center seat/armrest,Clear corner lenses,TT mirrors, Rancho RS 9000X with incab remote, A work truck you can valet. NRA Life member.
2004 F250 6.0 Harley Davidson 4x4 crewcab
2007 F350 V10 Tow truck with selfloader
2003 F 550 7.3 Crewcab Fith wheel hauler
twinbulls is offline
post #2 of 8 (permalink) Old 07-18-2001, 10:21 PM
HeavyAssault's Avatar
My Photos: (6)
Re: reset computer best way ??
I was told 5-10 mins. Not too sure about a fuse, I think the computer has an alternate wire feed to prevent loss of data. [img]images/icons/smile.gif[/img]
How do you like the POWERAID?? How about the install??
Overall comments?
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
post #3 of 8 (permalink) Old 07-18-2001, 11:10 PM
Disconnect the battery and turn the headlights on. Wait about 15 minutes. Turn the headlights off and reconnect the battery.
NoMo is offline
post #4 of 8 (permalink) Old 07-18-2001, 11:53 PM Thread Starter
twinbulls's Avatar
Poweraid spacer install easy 30 min..It has a whining noise when you open up the throttle, sounds ok throttle response MUCH better feels like it added a power band or brought it out more!! I installed the K&N FIPK at the same time so between them I am happy !
Next is headers and the exhaust then hypertec
I saw a spacer on e-bay 40$ cant beat it
post #5 of 8 (permalink) Old 07-20-2001, 06:20 PM
NoMo,
Just disconnecting the battery won't do the trick? I am curious what turning the lights on after the battery is disconnected does.
Thanks,
99.5, F250, CC, XLT, 4x4, V10, Auto,Off Road Pkg, Dark Tourmaline, 4" BDS lift, 315/75/16 Durango AT, Eagle 16x10, light tan interior, 6-way Power Seat, Chrome Grill Insert, Clearance Lights, 3.73, LS, Roll-n-Lock bed cover, driving lights
Testosterone is offline
post #6 of 8 (permalink) Old 07-20-2001, 10:41 PM
Residual voltage (due to circuit capacitance) tends to be sufficient to keep the PCM "powered" for quite a while. Turning on the headlights helps to drain this residual voltage pretty quickly.
At least that's the best theory I've got. [img]images/icons/smile.gif[/img]
NoMo is offline
post #7 of 8 (permalink) Old 07-20-2001, 11:09 PM
Remove both cables from the battery and touch them together, wait 30 minutes before re-installing the cables to the battery, this resets the computer,
2001 F250, XLT, V10, 4X2, SuperCab, Shortbed, Black, Auto, new model Parchment Power Seats, 3.73LS, OEM Tow Package, Power/Telescoping mirrors, Dlx Aluminum Wheels, Line-X Bed Liner, K & N Replacement Filter, OEM Mud Flaps & OEM Fog Lights, Ultimat, Ventvisors, Timbren Aeon Springs, Lund Stainless Steel Bug Guard, Street Scene Grill, Century Cargo Cover sprayed in Line-X, Walker Big Truck Xcelerator Muffler.
1999 Chevy G3500 Cargo Van, 5.7L, K & N Replacement filter, true Flowmaster duals, Dashmat, Line-X Interior, Shift Kit, Tow Package.
jlsworks is offline
post #8 of 8 (permalink) Old 07-21-2001, 03:52 AM
I reset mine by just disconnecting the battery for about 15 min. I had a trouble code show up when I forgot to hook up the wire from the filter - throttle body duct when putting on the headers. [img]images/icons/blush.gif[/img] The short disconnect cleared the code and computer.
1999 F250 SD SC SB SRW V10 A/T Lariat 295/75R16 BFG's on 8 Centerlines, Detroit Locker, RS9000's, Ride Rites, Hellwig rear sway bar, Borla Headers, cat back duals, Banks intake kit, Zoodad, PIAA's, Tint, Blaupunkt SF reciever, 400W RMS Infinity Amp, MB Quart speakers, and more!
Dr Matt is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
