Re: Spark knock
Are you hearing the "spark knock" in a particular RPM range? Are you sure its not the infamous "flutter"?
If its not "flutter", it could be a bad knock sensor, or bad/low octane gas, or you're running too low in the RPM range (1500-1600 rpm under load uphill).
Y2k F350, white with harvest gold trim,V10,4x4,Lariat,SC,Auto,Tow pkg,camper pkg,ESOF, so-called limited slip, off road,3.73,Rancho 9000 w/ in cab control, Ride Rite Air Bags,Long bed,Rickson 19.5" wheels, Michelin XDE-MS,Lance Camper, BugDeflector2, Stull Grill, KN., Flowmaster 50
