Spark plug question - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 07-06-2007, 03:44 PM   #1 (permalink)
Spark plug question
One of our trucks has the V10 in it. On the way in to work yesterday morning, the fourth plug back on the passenger side blew out.
Big bang, followed by lots of little bangs....
Disconnected the coil, pulled the plug, and the first couple of threads on the end of the plug are bunged up.
With lots of sticky oil to hold on to shavings, I run a tap through the head - it runs through and back with no problem, but I can't get a new spark plug to thread into the hole.
Any ideas on what to do next?
CB
Big Red - 1999 F350 extended cab - flat dump bed - 7.3/6speed
POS # 1 - 1995 c3500 - died... ignominiously
POS # 2 - 1995 c3500HD (three engines in 135,000 miles - with regular maintenance)
Baby - 1996 international 4700LPX / DT444
Retired - 1989 F350 / 7.3 IDI 400K trouble free
Bertha - 1999 international 4700 / dt466
Pokey - international 4700 / 444
Beast - internatioanl 4700 / 466
Pony - 2003 F350 triton V10
Blue - 1991 F450 7.3L
My toy - 1997 Honda Valkyrie 1.5L F6
WildcatB is offline
Old 07-06-2007, 07:33 PM   #2 (permalink)
Re: Spark plug question
Two choices, Ford recommends to replace the head, as when the plugs pull out it takes the threads with it, you may have "some" threads left, but not enough to keep a plug held in there.
The second option is to install a Timesert(similar to Heli-coil, but different), Ford does not recommend head repair, but this can be done in chassis carefully, and there are many Ford techs/dealers and independent shops that have done this with great success, but most will not guarantee anything with it. Cost of doing the Timesert is somewhere around $300 for the kit plus the time of repairing the spark plug hole. Timesert website
Buddy
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip.
My Truck
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
budman451 is offline
Old 07-07-2007, 10:26 AM   #3 (permalink)
Any idea what kind of price I should expect for a head replacement? Just so I have some notion before I start talking to mechanics.
Thanks again
CB
WildcatB is offline
Old 07-07-2007, 02:24 PM   #4 (permalink)
Labor time to replace the cylinder head is approximately 12 hours, plus the cost of the cylinder head. When I replaced the heads, they also got 10 new spark plugs, one new coil, as the coil tends to break the mounting ear off, gaskets, oil & filter, coolant, and usually some other miscellaneous items that may be found to be damaged/worn from normal use such as hoses, timing chains/guides, and the COP boots.
Buddy
My Truck
Old 07-09-2007, 05:07 PM   #5 (permalink)
Ouch. Thanks.
One other thing - I've been told two different things about this plug. Several people have told me that the only reason a plug would blow out is if was installed loose or cross-threaded. Two people have told me that it's, "a common problem with that enigne."
Who should I listen to on this? (In other words, since the guy who instaled the plugs last time is one of the guys telling me it's a common problem, is he being straight with me or is he fullovit?)
Thanks again
CB
WildcatB is offline
Old 07-09-2007, 08:45 PM   #6 (permalink)
Yes, this is somewhat of a common problem, and every V10 that I have done head replacements on because of plug blow outs, it has always been cylinder #4, fourth back on passenger side every time. Somewhere in 2001 or 2002 there was a casting/machining change to increase the number of threads from 4 to 6 or 8 to help prevent that problem.
The Triton engines is one of the very few engines where I will demand only OEM parts and procedures. I very strongly recommend only the Motorcraft plugs, as they are supposed to have a coating on them, so no anti-seize should be used on the threads, where I do not see anything like that on aftermarket plugs. IIRC, 13 ft. lbs. is the torque spec on the plugs. The threads can be stressed easily in the head from overtorqueing or blown out from undertorqueing, so a good torque wrench is mandatory on these engines IMO.
Buddy
Old 07-09-2007, 08:56 PM   #7 (permalink)
Pappy19's Avatar
My Photos: (6)
Buddy-
So in your experience, the blown plug problem in the V-10's disappeared after 2002?
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Magnaflow, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i, MagHytec rear dif cover.
2007 Lincoln LT (wifer's grocery getter),Superchip,Magnaflow duels, K&N dropin, Leer Browning Special
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies.
pappy's truck
Pappy19 is offline
Old 07-09-2007, 09:51 PM   #8 (permalink)
The problem did not completely disappear after 02, it was still there, just seemed to occur much less. With the new 3v design V10 in the 05+, including the engine that should be in your future new 08, I have not seen any major plug blowout issues with them.
Buddy
Old 07-09-2007, 10:19 PM   #9 (permalink)
Pappy19's Avatar
My Photos: (6)
Buddy-
Again, thanks for the input. What, if any, problems have you consistantly seen in the V-10 since 2005, and how are they determined or avoided? People that have newer V-10's that I have talked to, don't seem to have many issues except the age old complaint of low gas mileage. But many of the 6.4 owners have the same complaint.
pappy's truck
Pappy19 is offline
Old 07-09-2007, 10:48 PM   #10 (permalink)
Problems that I've seen fairly common, at least with the 05-07 Super Duty V10 platforms, mostly consisted of slow fuel fills caused by a plugged EVAP canister especially around here where the oilfield roads will plug them up quick with dust, false overheats, engine stalling/no response caused by a bad TPS or throttle body assembly. There were also quite a few problems with instrument clusters and some problems still with the rear wheel speed sensors.
Most of these concerns have TSB's out on them. As to how many of these problems may transfer to the new 08's, I am not sure. I left the dealer back in February and only dealed with one new 08, and that was a plain jane XL 5.4 that I did a PDI on. I never read too much in the 08 WSM or PC/ED's to see how much stuff was changed to see if any of the common problems may carryover.
Buddy
