Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Gas Engines
Gas Engines Discussion of the gas engines available in the 1999-2007 Super Duty trucks
Old 10-17-2007, 11:37 PM   #1 (permalink)
Tale of woe
I've had an ABS light problem ever since I bought my '02 F250 4x4. I thought it was the VSS, like on my '89 but replaced it (and the pigtail), and no luck. No codes, nada, so I finally decided to take it to the dealer and let them work for a couple of hours. I figured maybe they had more sophisticated diagnostic tools and could narrow it down. Well, first they called and said it took them two hours to not get any codes, road test, and decide that it had "bad battery & cable ends", so the tester can't get a good signal. Hmmmm... new battery 18 months ago, starts quick every time, but ok, maybe a cell went bad, and like I'm going to take the car back, put on new connectors and take it back to the dealer?
So, I said ok, and now I have a $500 battery & cable job, but they call back and say "bad coil pack somewhere is arcing and interfering with the testing tool". They want $365 to pull all the coils and test. Ummmm... I can get eight new coils for less than that and install them in an hour? And what kind of magic tester is this anyway?
Argh, anyone else solve an intermittent ABS light problem?
Can anyone recommend a decent Ford shop near Petaluma, CA?
jkloepping is offline
Old 10-18-2007, 08:01 AM   #2 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Re: Tale of woe
If their diagnosis (sp) did not fix the problem make them put it back the way it was or not charge you.
I have had to do that before.
MarkEkberg is offline
Old 10-25-2007, 12:08 PM   #3 (permalink)
Re: Tale of woe
Any updates?
Robb Wing from Cincinnati,Ohio FOKISD Charter Member/Founding President
99.5 F250SD XLT,4X4,CC,SB,SRW,V10,Auto,3.73LS,ESOF,Deep Wedgewood Blue,Swiss Cab-high Cap,Pioneer DEH-P7300,Alpine Amps,Infinity Sub,Street Scene Grill Inserts,full-chrome grill,Fumoto,SPA Gauges,Rancho 9000s w/remote & stabilizer,Heated/Lighted TT mirrors, Jordan Ultima 2020,TYC Elegante Tail Lights,Great Covers Endura Seat Covers,Auto Lock Underseat Drawer,Hella Micro DE Fogs,Full Chrome Front Bumper,PML Diff Cover, JAD Solutions LED running lights below doors,18" Harley Wheels,keypad,chrome tow hooks,leather steering wheel, PF 2-piece Rotors and "Z" pads in front - PS Cryo and Hawk LTS in rear,BANKS Stinger Plus,Banks TransCommand,GMT Transmission My Pics
todlake is offline
Old 07-05-2008, 02:46 PM   #4 (permalink)
Intermittent ABS light SOLVED!!!!
Ok, my ABS light was occasionally coming on, especially on hard acceleration, downshifting of the auto trans. I also had some other strange electrical issues - radio randomly shutting off for example.
It turns out that a coil pack can fail in a strange way. The high voltage side of the coil apparently shorts to the low voltage side, occasionally scrambling any sensitive electronics in the car. Apparently the ABS module is the most sensitive part.
I swapped four of the coils with new ones, and when that didn't solve the problem, I swapped them with the other side and presto! No more problem.
