Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Gas Engines
Gas Engines Discussion of the gas engines available in the 1999-2007 Super Duty trucks
Old 04-03-2002, 02:00 PM   #1 (permalink)
Test Pipe??
Does anyone know where to get a test pipe in order to take off my catalylic converter? Can I get one from a local muffler shop when they install my Flowmaster 40 series or do I have to order one?? I'm clueless, help.
-MINDCRIME-
2000 F250,V-10,CC,Lariat,4x2, Black, short box,3.73'S, Goodyear ATS 305/70/16's, Billet Grill, Limo Tint, Chrome bed rails and nerf bars, 50 Series Flowmaster, 2002 Headlights
Mindcrime is offline
Old 04-03-2002, 05:15 PM   #2 (permalink)
Re: Test Pipe??
test pipe? what is that?
if you just want to delete your cat, just have the muffler shop cut the pipe before the cat... then when the put in your flow, they can weld a straight piece from that cut to the muffler.
some shops might not do this as it is illegal.... but keep looking if the shop you had in mind says no... plenty will do it.
<font color="#a1a1a1">
Forward, lamefoot!. . .What are you doing here between towers? The tower is where you belong.
You ought to be locked up; you block the way for one better than yourself. - Nietzsche
</font color>
my truck
abendx is offline
Old 04-03-2002, 06:01 PM   #3 (permalink)
Re: Test Pipe??
I used a peice of 5x5x3/8 plate and cut a 3" hole in it with a hole saw, marked the flange holes drillled them then welded a 3' peice of 3" pipe into the new flange. I didn't really think that it gave any more power that I was looking for. It certainly did let a WHOLE bunch of sound through if that's what your looking for. The worst part about it was that it made my Flowmaster muffler sound like a coffee can. I have since put the CAT back in place, the coffee can sound drove me crazy.
04/04 F350 Dually Lariate, 4x4, CC, LB, Auto, Firestone air bags, Bilstein shocks, custome on board air system, cat back 4" Aeroturbine muffler.
04/03 F350 Dually XLT, 4x4, CC, LB, Auto, Firestone air bags, Bilstein shocks, Three rear main seals, three times for no 4x4, to many other problems, Dealer got this peice of junk back in less than three months.
02, (Traded 12/01/03) F350SD,XLT, 4X4, CC, LB, PSD, Auto, Firestone air bags, Bilstein shocks
Custome made ATV rack
350R is offline
Old 04-05-2002, 01:36 AM   #4 (permalink)
Re: Test Pipe??
I did exactly what F350 did. Cut some flanges and even made flanges for both ends so replacement would be easy. Let me tell you it got LOUD! I noticed no improvement in power/mpg. I had the cat out for a week and couldn't stand it any longer.
I put the cat back. I wouldn't recomend removing the cat. BTW, the cat is huge inside. Plenty of cross area. It's also like a thick window screen. You can see light through it.
2005 V10, AT, Fx4 Dark Stone Metalic, Crewcab F350, 4.10LS, shortbed, towcomand, Extang tonno **SOLD**
2007 Dodge 3500 Quadcab, 4x2, 6.7L Cummins, a/t, longbed, 4x2
Silence is golden. Duct tape is silver.
V10 man is offline
Old 04-09-2002, 11:59 AM   #5 (permalink)
Re: Test Pipe??
Why not straight pipe it(the muffler) first just to check it out......unless too many have already done it with miserable results? We'll put the stocker back on if it doesn't work out.
You know how the SC sounded with 2 chamber flows and no cats - "coffee can" is right. I think cats would have toned it down favorably. Granted it was a 6.
straight pipe:
- 1 pipe cutter
- 1 3' mild steel pipe or flexpipe
- 2 band clamps (to get it to the muffler shop for a quick weld if it sounds good enough to keep)
- 1 case o' suds
- 1 afternoon on the driveway
- 1 quick trip around the block with no muffler and pipe termination under the truck just to scare the kids and grannies at the grocery store
Anyone tried a Dynomax welded oval or bullet . . .or Borla XR1? Magnaflow resonator with straight pipe and no muffler? Can you comment relative to Ford Windosor V8 sound?
'01 F250 CC PSD 4x4 Lariat, auto, ESOF, 3.73s; born on 5-01; Ranch Hand front and back; Weatherguard box; Optima reds; Bilsteins, Powerstops and Hawks at 80k; Rotella T and Motocraft filters; 95k miles as of 8/06; 275/65/20 Goodyear Wranglers
BPUs: Zoodad mod (where's his royalty check), AFE II, MBRP 4", DI 6 position, Autometer Phantoms on A-pillar and under the dash
Plans: heavier front leaf springs, F350 rear blocks, more power . . .
3 back surgeries and one rear-end accident later - screw the other guy, I'm in the big truck this time!
backpain is offline
Old 04-09-2002, 12:10 PM   #6 (permalink)
Re: Test Pipe??
the 10 will never sound like the 8..... just get it out of your mind..... it is a lost cause to be looking for that nice 8 sound!
now... the straight pipe... i was going to go this route at first but two seperate muffler shops as well as a buddy that is a service manager for ford talked me out of it... all calimed that the lack of back pressure that the muffler provides would mess with the O2 sensors. (but, those that have a striaght pipe have not piped up with any complaints...)
</font color>
my truck
abendx is offline
Old 04-09-2002, 01:56 PM   #7 (permalink)
HeavyAssault's Avatar
My Photos: (6)
Re: Test Pipe??
I was running a straight pipe. Had them cut out the muffler and weld in a shaped pipe. Was fairly loud when you got on it. I would cause car alarms to go off just from starting up if they were parked beside me. I never had any O2 sensor problems. I run headers and the 40 series Flowmaster now. Getting a mic soon so I can post the sound wav.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some "deleted" stuff.....
HeavyAssault is online now
Old 04-09-2002, 02:08 PM   #8 (permalink)
Re: Test Pipe??
cool... can't wait for the clip... i think headers may be one of my future upgrades! [img]/ubbthreads/images/icons/smile.gif[/img]
</font color>
my truck
abendx is offline
Old 04-10-2002, 04:37 PM   #9 (permalink)
Re: Test Pipe??
<blockquote><font class="small">In reply to:</font><hr>
the 10 will never sound like the 8..... just get it out of your mind..... it is a lost cause to be looking for that nice 8 sound!<blockquote><font class="small">In reply to:</font><hr>
Agreed. Just trying to talk about it relative to something we all know - at least a reference point to compare tone, volume, etc. Granted, 10 cylinders fire differently than 8 and it's gonna sound different no matter what.
backpain is offline
