truck wont start, sputters and backfires out intake! - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 07-20-2009, 08:48 PM   #1 (permalink)
farnereinar's Avatar
My Photos: (6)
i picked up a 2001 f-350 5.4 for a steal of a deal, the guy said the motor was knocking, but ran still when it was parked, 3 months ago
i picked up the truck and put in a new battery (so now i have no codes) and upon starting it wants to backfire out the intake, will barely run on ether....i can hear the fuel pump working & verified the truck has fuel
almost sounds like when my other 5.4 had mass airflow sensor problems, you can put the pedal to the floor, and sounds like it wants to fire up, but wont
any ideas? i think its electrical.....being that if im shooting either in it...its doing the same thing as if no ether..
daily: 2000 F-350xl 7.3L 4x4 SRW Reg Cab, auto, edge juice with attitude, DIY intake, 4" exhaust, 2.5" lift front & rear, 33" goodyears
work: 1995 F-superduty 2x4 7.3L Dump e40d, heavy and slow
1985 F-350 Diesel 6.9 4x4 Reg Cab SRW c-6 automatic connected to a borg-werner 1345 TC, 4:10 posi d-50 front and sterling 10.25 rear, TTB, A/C, new springs, shocks, starter, 450amp alternator new floors rockers wheel wells, doors, hood, fenders & black paint
HERE SHE IS
accident in feb. 2006 left her totaled, but will be re-bent to perfection in time.
dads: 1992 non-turbo 7.3 e4od 4x4 extended cab 3.73rears 265k miles, runs like crap, looks like an angry cloud.
farnereinar is offline
Old 07-21-2009, 10:33 PM   #2 (permalink)
hco4x4's Avatar
check to make sure all your hoses are hooked up. mine did the same when i had a hose off
hco4x4 is offline
Old 07-24-2009, 01:23 AM   #3 (permalink)
fulltimer50's Avatar
My Photos: (16)
Firing out the intake is almost always a timing or wiring problem. Check the plug wiring with the firing order to be sure they are correct. Not sure about how to check the time on the new engines, but basic timing must be the same as it always was. Check with a timing light.
George
6/2011 F350 PSD Lariate, CC, 4x4, LB, DRW
06 Newmar Cypress 29KSRE 5th wheel/MorRyde IS, Kodiac Disc Brakes.
fulltimer50 is offline
Old 07-25-2009, 02:15 PM   #4 (permalink)
akrewat's Avatar
A couple of easy things to check.
Check the fuel pressure and make sure as you cycle the key a few times that you have 38-40 pounds or so at the fuel rail.
Check the red wire at the injectors, with the key on, and make sure you have 12V.
See if you can verify that the injectors are getting a signal. A digital volt meter with a "peak" setting, or set to AC volts, connected to an injector connector, and crank and see what you get.
You could also try disconnecting the MAF entirely and see if it'll start.
'01 F250SD V10 auto 4x4 SC SB Volant CAI, ebay headers/y-pipe
'74 F250HD FE390 4-speed 4x4 LB - heavily modified 390 (deceased)
akrewat is offline
