Re: Using the engine for braking
The engine will not work as a brake at low speeds very well. The computer is telling the tranny to disengage to let the truck coast and thereby improve milage. If you start at greater speeds you can get this to work by downshifting and then using the throttle to get the engine up to vehicle speed. Compression will slow the truck down & it will work better than if you do not get the tranny locked up. This way the computer sort of figures out you are compression braking and cooperates better. This may not be a technically accurate description but it works.
1999 F250 SD SC SB SRW V10 A/T Lariat 295/75R16 BFG's on 8 Centerlines, Detroit Locker, RS9000's, Ride Rites, Hellwig rear sway bar, Borla Headers, cat back duals, Banks intake kit, Zoodad, PIAA's, Tint, Blaupunkt SF reciever, 400W RMS Infinity Amp, MB Quart speakers, and more!
