Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Gas Engines
Gas Engines Discussion of the gas engines available in the 1999-2007 Super Duty trucks
Old 12-18-2006, 08:50 PM   #1 (permalink)
V-10 ?
hey ? for all u v10 guys. my cousin does maintance on his boss's excursion and he said for the last 2 oil changes it seems like only 2-3 is all thats draining from the pan when he changes it. he said he looked it over really well and cant find any visible leaks nor does it appear to be burning any. no smoking or anything that would lead one to believe its burning it. no signs of any in the coolant.??????
he doesnt have comp access and ive never seen the truck. just figured id see if anyone here had seen something remotely close to this.
96 f250( Big Foot ) 3" downpipe, 4" exhaust(no kitty or muffler), ancient superchips program, shimmed fpr, intake, guages....thats it for now
future.......i still dont know what direction i want to go yet
lorha11 is offline
Old 12-20-2006, 12:32 PM   #2 (permalink)
RightWingNutJob's Avatar
Re: V-10 ?
I'd think you'd see or smell some evidence 3-4 quarts of oil disappearing. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Are you sure it was being filled up with the right amount in the first place? There was a recall on V10s, like 5 or 6 years ago where they were shipped with improperly marked dipsticks. If you put in the recommended amount of oil, the dipstick showed it as being about an inch or more above the "full" line. But I thought this problem was mostly found on motorhome chassis.
'01 F350 XLT, CC, 4x4, V10, SRW, LWB, Auto, 3.73LS, Island Blue, Off Road Package,
Auto Hubs & Cab Clearance Lights. Autometer water temp, tranny temp, & vaccuum
gauges. Line-X Bedliner, & the "incredible self-locking tailgate." White Night Backup
Lights & Volvo-eating Class V Hitch. Reverse Sensors.
RightWingNutJob is offline
Old 12-20-2006, 02:33 PM   #3 (permalink)
Re: V-10 ?
yeah same here. my cuz has been a tranny man all his life sooo i know that he isnt a dummy and like i said i havent seen the truck. but it makes no sense at all. however the dipstick would make it make sense. thanx
lorha11 is offline
Old 12-21-2006, 02:59 PM   #4 (permalink)
Re: V-10 ?
The dipstick isn't going to account for that big of a discrepency. Allowing a quart+ or so for the filter, you should still get 4-5 out of the oil pan. The V10s will "use" some oil between changes. Many will lose up to a quart every 3000 miles and this is considered "normal" by Ford. Next time he changes the oil, tell him to check the level on the dipstick first. If he's down as far as you've said, he won't show much if any on the dipstick.
Robb [img]/ubbthreads/images/graemlins/smile.gif[/img]
Robb Wing from Cincinnati,Ohio FOKISD Charter Member/Founding President
99.5 F250SD XLT,4X4,CC,SB,SRW,V10,Auto,3.73LS,ESOF,Deep Wedgewood Blue,Swiss Cab-high Cap,Pioneer DEH-P7300,Alpine Amps,Infinity Sub,Street Scene Grill Inserts,full-chrome grill,Fumoto,SPA Gauges,Rancho 9000s w/remote & stabilizer,Heated/Lighted TT mirrors, Jordan Ultima 2020,TYC Elegante Tail Lights,Great Covers Endura Seat Covers,Auto Lock Underseat Drawer,Hella Micro DE Fogs,Full Chrome Front Bumper,PML Diff Cover, JAD Solutions LED running lights below doors,18" Harley Wheels,keypad,chrome tow hooks,leather steering wheel, PF 2-piece Rotors and "Z" pads in front - PS Cryo and Hawk LTS in rear,BANKS Stinger Plus,Banks TransCommand,GMT Transmission My Pics
todlake is offline
Old 12-22-2006, 04:06 PM   #5 (permalink)
Re: V-10 ?
Is anybody checking the dipstick between oil changes on this thing? It ain't good to run them that low. The oil pressure switch only needs 7 psi to keep the warning light off, but 7 psi doesn't give a whole lot of lubrication where it's needed.
'00 F250 CC SWB 4x2 XLT V-10 Auto 3.73LS Silver/Graphite
Sport is offline
Old 01-10-2007, 09:59 PM   #6 (permalink)
Re: V-10 ?
My V-10 takes 6 qts and at every oil change its short 1 qt. been this way since about 30k miles...
I have NO leaks..... So its must be burning it ?????
Tim
1999.5 F-250 Lariat SD CC SRW LB Loaded V10 auto 4x2 K&N FIPK,Poweraid spacer,muffler deleted,custom seat covers,wood dash kit,tinted windows.BFGs 285s. A-Pillar gauges Tranny temp,oil pres and water temp.Hypertech PP 111 with themostat 160 deg.
ARE Custom Top W/ladder rack,Added a center seat/armrest,Clear corner lenses,TT mirrors, Rancho RS 9000X with incab remote, A work truck you can valet. NRA Life member.
My Truck
twinbulls is offline
Old 01-12-2007, 01:22 PM   #7 (permalink)
Re: V-10 ?
Has he measured how much oil he drains? The 5W-20 oil drains pretty quick when it's hot. Maybe he's draining more than he thinks he is. You said he's a tranny man. Transmission fluid drains like molasses compared to MC 5W-20.
Sport is offline
Old 01-20-2007, 11:28 AM   #8 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Re: V-10 ?
The filters are 1 qt. or close to it.
If you down a qt when you drain then all that is going to come out is 4 qts.
I agree with above statement. Is anyone checking the level during normal operation? My 7.3 hold 4 gal and I check it every other fill up.
MarkEkberg is offline
Old 01-26-2007, 11:25 PM   #9 (permalink)
Re: V-10 ?
I bet it takes 15 minutes for all of the oil to drain out of the engine to the oil pan, It probably holds a quart up there for ten minutes. 10 pistons and rods worth and the huge cylinder heads. Does he pull it in and just drain it or does he walk in and just drain it after it's been sitting?
1985 F350 6.9 w stock dana 60 and skyxxacker 4" springs in front, needs everything, except front springs. 1972 cub cadet 122, 90 lb x 2 wheel weights, oem weight box, ag tires, oem roof with windshield wiper, oem snowplow, ag seat with seat spring and mount from 100 or 70. so heavy, when it gets stuck I have to use the ford.
rdirtycar is offline
Old 01-26-2007, 11:26 PM   #10 (permalink)
Re: V-10 ?
and the filter
Old 01-27-2007, 07:44 PM   #11 (permalink)
Re: V-10 ?
Mine uses 1 qt of oil every 2500 mile or so. I thought that was a bad thing but I guess it's not so bad.
Jon
2001 F-350 4X4 Crew Cab Lariat Short Box Auto
2000 Excursion Limited V-10
Jon_in_MI is offline
Old 01-29-2007, 03:03 PM   #12 (permalink)
Re: V-10 ?
Jon,
How many miles do you have on your vehicle? I have 78,000 and have not noticed any loss of oil, just curious.
Chris
99.5, F250, CC, XLT, 4x4, V10, Auto,Off Road Pkg, Dark Tourmaline, 4" BDS lift, 315/75/16 Durango AT, Eagle 16x10, light tan interior, 6-way Power Seat, Chrome Grill Insert, Clearance Lights, 3.73, LS, Roll-n-Lock bed cover, driving lights
photos
Testosterone is offline
