V-10 and antisieze - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 09-03-2008, 04:15 PM   #1 (permalink)
V-10 and antisieze
Do YOU use antisieze on the spark plugs or not? What is the recommended torque with or without antisieze?
I need to change the plugs on a '01 X and have read both sides and was wondering if it has ever been worked out which is the correct way.
panhandleredneck is offline
Old 09-03-2008, 05:38 PM   #2 (permalink)
NO antisieze. Antisieze will effect the torque. Buy good plugs and don't worry about them corroding. Avoid Champions. torque to 71-106 INCH pounds. (a little less than 9 ft.lb)
Dad always said,"Knowledge is limited but stupidity knows no bounds."
YT90SC is online now
Old 09-12-2008, 02:45 PM   #3 (permalink)
any body else?
1997 F-250, 7.3 PSD, 185,000 mi, crew cab, 4x4, short box, DIY Tymar, muffler delete, manual 4x4 hubs, DP 60hp flash
STOLEN 1-8-07
1999 F-250 born on date 6/98, 7.3 PSD, 135K, ex-cab 4X4, Tymar mod, muffler delete, key-in-ignition mod, more to come
Serious case of PMS since I found this site
Old 09-14-2008, 02:26 PM   #4 (permalink)
I would use antisieze and reduce the torque value by 30 percent.
2006 F-350 Lariat 4x4 CC SB, 6.0 PSD, Torqueshift, Dieselsite Coolant Filter, MagHyTec Diff Cover, more mods soon I hope.
Jaketye is offline
Old 10-08-2008, 07:08 PM   #5 (permalink)
diesel_brad's Avatar
I would use antiseaze. Anytime you combine ANY 2 different metals there will be corrosion, Especially aluminum heads and steel plugs. I believe in every auto manufactures manuals they tell you to use it on alum heads
86 F250 6.9 4spd 4x4 6"+315s's(coming soon POWERSTROKE,D60&zf5 )
00F350 Xcab Dually 7.3.ZF6, 4x4 SOLD
94 Lightning, Full Bassani exhaust,underdrive pullys, CAI, new paint w/ stripes
96F350, 4dr, 460, ZF5, 6"lift, 35"thornbirds, banks torque tubes, 3"custom bent exhaust, bbk throttle body, stull grill, clear front turnsignals, lund visor, 3.55gears
1980 F350 PULLIN TRUCK, 429, C6, detroit lockers f&r 10.25/D60 33' BFG muds
diesel_brad is offline
Old 11-20-2008, 08:35 PM   #6 (permalink)
TonkaThunder's Avatar
My Photos: (6)
I would use anti-sieze.
03 F-350 DRW Lariat 7.3,4x4 6-Speed, 4.10Gears , 4 inch ProComp lift, BFG AT LT315/75R16, 3 in. spacer between duals.
GT38R 1.0 Housing
Banks Monster Exhaust, w/Turbo Elbow, AFE Stage 2 Cold Air Kit, South Bend Stage 2 Clutch and Cyro'ed Flywheel
DP 80econ -Stuck there for now because someone stole my SCT box
2 Optima Red Tops
Auto Meter Boost and Pyro Gauges
8,200lbs---Cat Scale---Thats me and and 38 Gallons of Diesel
1987 Mustang GT Cobra Clone- crate motor, cage and more suspension than I know what to do with
Loves to run down Vettes and Vipers on the road course
34 Ft Kaufman Solid Deck 2-Car Hauler
TonkaThunder is offline
