V-10 Tranny troubles - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 05-24-2003, 07:45 PM   #1 (permalink)
Towed my boat 200mi. on Thursday and noticed a burning smell but could never locate the source. Made the same tow today and 3 miles from home I looked in the mirror to see smoke trailing from the truck. I pulled over and noticed tranny fluid on the exhaust and when I got home I located the source. The fluid is coming from the hole in the bottom of the torque converter housing. The only thing ever done to the tranny is a new filter and swapped to Amsoil about three months ago. Help me out guys, whats the problem.....Thanks...
99 F-250SD Lariat, Ext. Cab, 4WD, V-10, 4.30, Auto, Towing machine.
crich is offline
Old 05-24-2003, 07:47 PM   #2 (permalink)
Re: V-10 Tranny troubles
Is it possible that you overfilled the tranny with fluid?
2003 F350 XLT CC 4x4 PSD - My ride - Banks Monster Exhaust, SCMT, Autometer guages, 6" ProComp lift on dual Fox shocks in front single in rear with Fox steering stabilizer.
2003 F150 XLT SuperCrew 4x2 5.4 V8 - Wife's ride - Not sure if she'll let me modify this one yet or not.
03psd4x4 is offline
Old 05-24-2003, 08:31 PM   #3 (permalink)
Its possible, but it was serviced 3 months ago. Unless the hotter days are causing the transmission to run a little hotter. If that is the case then where is the overflow leaking from? The boat only weighs around 2500 lbs, but I was towing hard. 75-80 mph Interstate with lots of hills. I towed the same boat 400 miles two monts ago, same driving styl with no problems.
crich is offline
Old 05-24-2003, 10:53 PM   #4 (permalink)
Isn't there a drain on the torque converter? It might be coming from it...
1999.5 F-250 V-10 4x4 CC SWB Lariat 3.73 Rancho 9000 K&N Flowmaster Delta 40
DJR 17 is offline
Old 05-27-2003, 09:20 AM   #5 (permalink)
I just had my 2nd tranny r&r'd for the same thing a couple weeks ago [img]/ubbthreads/images/graemlins/frown.gif[/img]. It got progressively worse to the point where I was leaving a trail just pulling it out of the drive onto the street (cold engine). Do not drive the truck as the fluid is running out the inspection plug and draining into the heat shield. The potential for flash fire is good [img]/ubbthreads/images/graemlins/shocked.gif[/img]. More than likely your torque converter has failed. There is a tsb (I don't have the #) for it. My dealer replaced the TC, front tranny pump, a bunch of seals and gaskets. Just towed the camper home yesterday with no problem. Take it to the dealer asap if you're still under warranty. Also, check your PM.
Robb [img]/ubbthreads/images/graemlins/grin.gif[/img]
Robb Wing from Cincinnati,Ohio
99.5 F250SD XLT,4X4,CC,SB,SRW,V10,Auto,3.73LS,ESOF,Deep Wedgewood Blue,Swiss Cab-high Cap,Pioneer DEH-P7300,Alpine Amps,Infinity Sub,Street Scene Grill Inserts,full-chrome grill,Fumoto,SPA Gauges,Rancho stabilizer,Heated/Lighted TT mirrors, Jordan Ultima 2020,TYC Elegante Tail Lights,Great Covers Endura Seat Covers,Auto Lock Underseat Drawer,Hella Micro DE Fogs,Full Chrome Front Bumper,PML Diff Cover, JAD Solutions LED running lights below doors,18" Harley Wheels,keypad,chrome tow hooks,leather steering wheel, PF 2-piece Rotors and "Z" pads in front - PS Cryo and Hawk LTS in rear,BANKS Stinger Plus,Banks TransCommand,GMT Transmission,Bilstein 5100s My Pics
todlake is offline
Old 05-27-2003, 02:47 PM   #6 (permalink)
Thats not what I wanted to hear [img]/ubbthreads/images/graemlins/mad.gif[/img] Sounds expensive. The truck has 55K on it and no extended warranty. Maybe its time to trade or I may just keep driving it and keep a fire extinguisher close at hand [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Was the torque conv. bad or just leaking? The tranny shifts normal.
crich is offline
Old 05-27-2003, 03:01 PM   #7 (permalink)
Crich,
My torque converter apparently went bad, wouldn't lock out. I knew something was up when I lost about 3 mpg this past winter. The other possibility is that you have a bad TC seal. If the TC is still locking out, that may be all it is. I wouldn't try to get out of your truck just because of this, used values are really low and if that's the only problem with your truck, fix it and get on with it. Find a reputable tranny shop and get an estimate for both repairs. You may consider an aftermarket TC like Suncoast if you have to replace it. Maybe put in the Sonnax and Tricumulator mods too. If it's gotta be apart, might as well strengthen it.
todlake is offline
Old 05-27-2003, 03:54 PM   #8 (permalink)
Thanks for the info Robb. I really dont think I have a problem with the TC, cause its shifting and pulling normal. I did drive it 45 miles to work today and looked at the leak when I got to the parking lot and there was no fluid coming from the grommet hole but there was fluid coming from the x-mission/shield seam. If you reach your finger in the grommet hole you will find fluid, but Im still not sure the exact location of the leak. A good friend of mine owns his own auto repair shop and has been turning wrenches on cars since to 50's swears up and down its the synthetic lube that has caused the leak. He told me to swap back to what Ford puts in and if I'm lucky the leak will stop [img]/ubbthreads/images/graemlins/confused.gif[/img].
crich is offline
Old 05-28-2003, 09:10 AM   #9 (permalink)
Crich,
It may be the synthetic (let's hope), BUT, an awful lot of folks are running syn with no problem. Unfortunately, the 4R100 can be a problem child...
todlake is offline
